Build thread '70 H code Mach 1.
Old Dec 22, 2010 | 06:07 PM
p4lm3r's Avatar
p4lm3r
Default Build thread '70 H code Mach 1.
Unfortunately I didn't take 'before' pics, but the front and back bumpers were shot, the pass fender and headlight bucket were badly dented, the Ivy interior was shot, and the hood has some significant rust. As you can see it is sitting on MOPAR wheels, but the Mag 500 15X8's will be in tomorrow. Current costs: $8k for the car, $5400 in reciepts.
Battery box is rusted out, but other than that, great metal
Bumper and valance were shot.
replacing the drivers door, some 30yr old body work was done poorly.
dash pad and all guts out.(special thanks to the member that gave me pointers on dash pad removal)
Rear bumper, valance and decklid are going.
This pile used to be attached to the car.
Will keep this thread up to date as the build continues.
Old Dec 22, 2010 | 06:19 PM
gconnsr's Avatar
gconnsr
Right on, Good luck with the build!
Old Dec 23, 2010 | 05:40 AM
tx65coupe's Avatar
tx65coupe
That has a lot of potential. Can't go wrong with the Magnums. I hope it turns out sweet! I look forward to future pics.
Old Dec 23, 2010 | 09:16 AM
69mach1377's Avatar
69mach1377
When you are done, these will be the before pics and you will be very proud of the transformation.
Good luck.
Old Dec 23, 2010 | 03:31 PM
p4lm3r's Avatar
p4lm3r
Thanks everyone. Just called it a day. Tore out the radiator, pulleys, ac compressor, engine wiring harness, Crank turns great. Hoping to have the motor out tomorrow. A friend has been doing the sanding. Going slow, but lots and lots of great steel under the paint.
Old Dec 23, 2010 | 03:54 PM
Dro21's Avatar
Dro21
Nice, Ill be watching this build
Old Dec 24, 2010 | 11:03 AM
hightower2011's Avatar
hightower2011
Same, this build is gonna be great!
Old Dec 24, 2010 | 05:07 PM
p4lm3r's Avatar
p4lm3r
Didn't get a ton done today, Mostly worked on stripping it for paint. Got all the moldings, trim, side markers, tail light trim, etc. off. Also had to remove the drivers side fender to inspect for rust. Everything is looking great. Also finished tearing down the front so that I can properly clean the engine bay and front clip so that I can give it all a proper paint job.
Just one picture today.
Old Dec 26, 2010 | 08:35 AM
palerider's Avatar
palerider
Good luck. I've got a 70 also. Nice year. Took me 3 weeks to strip it down to shell and 3 years to put back together. Hopefully your project will move faster than mine did.
Old Dec 28, 2010 | 10:23 AM
p4lm3r's Avatar
p4lm3r
Finally got parts in. Lots of parts.
