Homebuilt coilover system
Old Jan 27, 2011 | 12:40 PM
  #51
001mustang's Avatar
001mustang
Caster (deg) = (180 / 3.1415) * [(camber1 - camber2) / (turnangle1 - turnangle2)]
Shortcut for Caster w/ 20* turns:
Caster = 1.432 x (camber1 - camber2)
I used above equation and came up w/ factor of 1.43 w/ 20* turns.
Is the different factor of 1.5 vs 1.43 just rounding difference?
Old Jan 27, 2011 | 02:15 PM
  #52
Norm Peterson's Avatar
Norm Peterson
There is a little rounding going on, and it's going to be extremely difficult in DIY practice to hit a sweep angle to within much less than ±0.5° anyway.
1.5 is the factor that the caster-camber gauges that are available through the circle track supply houses use with their (claimed) ±20° sweep.
The difference between 1.5 and 1.43 is less than 0.3° with a caster setting of around 6°, so it's not a huge factor. I'd pay more attention to making the two sides either identical or with achieving a specific caster split (right side more + than the left) to help keep the car from drifting to the right on crowned roads.
Norm
Old Jan 27, 2011 | 02:22 PM
  #53
eZ's Avatar
eZ
Yes I believe its just rounded for ease of measurement. Im thinking of buying an alignment tool but Im getting a bit tired of working/welding/building/designing/ I really need to go for a drive and put a smile on my face.
If anybody wants to buy the shock mounts hit me up. They look much better TIG welded. Ill take more pictures. But probably $150 for the mounts w/mounting hardware and aluminum spacer only because its a full day of work for me.
Old Jan 27, 2011 | 04:54 PM
  #54
001mustang's Avatar
001mustang
Amen on the driving. I know how it feels.
Few alignment pointers:
Verify turntable floats freely under load; old turntable may be worn out.
I settle suspension and jog wheels before collecting final data.
Verify final data is collected after everything is torqued; (very important).
Old Jan 28, 2011 | 11:21 PM
  #55
jgemperline's Avatar
jgemperline
Thread of the month? Can you finish this thread with a video? Great work!
Old Jan 29, 2011 | 01:26 PM
  #56
eZ's Avatar
eZ
sure! video of what though? LOL driving?
Old Jan 29, 2011 | 03:12 PM
  #57
jgemperline
Sure! Take a few good turns, out and back? I don’t know, your car looks sweet in pictures, I bet it looks "bad ***" in video. I guess it does not really fit the thread (being a suspension build) but you have done some great work and thought it would complement your efforts. Thanks for sharing. Where did you find cromolly Hex bar?
Old Jan 29, 2011 | 05:00 PM
  #58
eZ's Avatar
eZ
chromoly hex bar I got off Amazon. You could parobably use a chromoly hex tie rod and drill for mounting holes. should still be plenty strong enough
Old Feb 1, 2011 | 03:50 PM
  #59
001mustang's Avatar
001mustang
Anxiously waiting for your test drive report.
Old Feb 1, 2011 | 04:35 PM
  #60
eZ's Avatar
eZ
Still playing with DIY alignment...LOL..got it pretty close though. taking it in tomorrow morning for a reputable shop. Just want to see how close I got it. First drive was awesome. Springs were a bit too soft even when stiffening the adjustment on the shock. Taking the 350's off today and putting on 450's. Should be just right! On a good note the whole system is very quiet. No more bushings no more bindings.
