carb spacer?
Old Jan 14, 2011 | 02:06 PM
001mustang's Avatar
001mustang
Will 4 hole spacer, 2 hole, or one hole spacer work better w/ edelbrock performer dual plane?
Think I installed 2 hole FWIR.
Old Jan 14, 2011 | 02:24 PM
eZ's Avatar
eZ
open spacer
Old Jan 14, 2011 | 02:32 PM
001mustang's Avatar
001mustang
Hmmm...maybe I will look use a bent probe or something (?) to determine which I installed. Guess that's doable? Runs good just curious.
Old Jan 14, 2011 | 03:04 PM
Norm Peterson's Avatar
Norm Peterson
An open spacer might give you a little more top end by virtue of each manifold plane being able to share some of the flow from the 2 barrels that normally feed the other bank. There may be a small airflow benefit from the air and fuel not having to make quite as sharp of a turn going into/through/out of the plenums into the runners themselves.
Your metering signal will not be quite as strong - I think that means that you'll be slightly lean and that tip-in response might be a little "lazy". Some carb adjustment may be necessary since carbs "out of the box" generally aren't calibrated with spacers in mind.
Norm
Old Jan 14, 2011 | 04:16 PM
001mustang's Avatar
001mustang
I don't get the so called "out of the box" carbs.
No one size fits all for carb tuning far as I know.
I know I had to tune my "out of the box" carb.
Old Jan 15, 2011 | 04:33 AM
nba1341's Avatar
nba1341
Originally Posted by maestro1024
I am probably picking up this spacer as my next Mustang purchase.
http://www.summitracing.com/parts/SUM-G1404/?rtype=10
Sounds like it may be what you need also.
why get that when you can get this for $10 cheaper and in black rather than ugly orange/peach whatever that color is
http://www.summitracing.com/parts/EDL-8711/
Old Jan 15, 2011 | 09:28 AM
Norm Peterson
Originally Posted by 001mustang
Interesting that my OEM 65 w/ cast iron intake manifold exhaust passage is more cold natured than my HP 67 w/ blocked exhaust passage aluminum intake manifold.
Aluminum conducts heat a little over three times as fast as iron does.
Although it requires more heat per unit mass to heat up, it's also less dense than iron. In relative terms here, assuming that the overall volums of metal are similar (numbers are from the engineering toolbox site)
iron = 0.11 * 7850 = 863.5
aluminum = 0.22 * 2712 = 596.6
What that means is it takes more heat to warm up the iron to begin with (which takes a longer engine running time), and due to its poorer heat conductivity it takes longer for that heat to evenly flow into all of the iron and get it to reach its steady-state temperature (aka fully warmed up). Sound like what you've observed?
If the heat passages in either head or in the manifold are clogged or caked with carbon, you already have restricted crossover flow (or perhaps none at all if any of them are caked completely solid with the stuff). If you do have any flow, there's a layer of carbon/soot that's acting like insulation, making the rate of heat flow into the iron that much poorer. Your intake gaskets are also insulators rather than good conductors (so not much help there), and the manifold bolts aren't going to be very helpful either. That leaves you with hot oil splashing against the underside of the manifold being the only significant source of heat, same as what you have with the aluminum manifold and a blocked crossover. And maybe a little heat coming from reversion pulses backing up into the intake from the cylinders during valve overlap.
Norm
Old Jan 17, 2011 | 03:06 PM
tdg01's Avatar
tdg01
I'm looking to do the exact same mod on my '65 2V. Can you tell me more about the carb and intake you purchased (Model, from where, etc)?
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
