drive shaft blues
Old Jan 20, 2011 | 05:34 PM
stangcoupe1970's Avatar
stangcoupe1970
Default drive shaft blues
I have an fmx transmission can the car came with a 351c, and I've seen more v-12's than 351c's, so my question is, is there any chance of finding a drive shaft that fits my needs? its supposed to be 50 5/8 and I cant find one anywhere..unless someone has a site I don't know about.
Old Jan 20, 2011 | 06:12 PM
Gun Jam's Avatar
Gun Jam
isnt that something that denny's can draw up and make custom?
eZ's Avatar
eZ
Ford part #
3x50 5/8 C9ZZ-4602-B
3 1/2 x 50 5/8 D0ZZ-4602-A (for 31 spline axles)
Old Jan 20, 2011 | 07:18 PM
stangcoupe1970
Originally Posted by eZ
Ford part #
can I go to ford to get it?
what if I get one that is within an inch on the original length?
Old Jan 23, 2011 | 09:19 PM
stangcoupe1970
What about shortening one?
Is it expensive/safe?
And where does it even done?
Old Jan 23, 2011 | 09:35 PM
Gun Jam's Avatar
Gun Jam
Any driveline shop can shorten one...it is safe...its also about 30 to 50% the cost of a new one assuming dennys would charge 300 ish
Old Jan 24, 2011 | 01:15 AM
andrewmp6's Avatar
andrewmp6
Call any big diesel shops around you i have had drive shafts made locally for around 300 bucks.
Old Jan 24, 2011 | 08:34 AM
F15Falcon's Avatar
F15Falcon
Here is an article I did last year:
Here is a pictorial on how to shorten your driveshaft. You may need to shorten your driveshaft because of a tranny change, rear end change or in my case, because I had no driveshaft at all for the '65 Mustang I am working on. This may be one of those projects people shy away from because they think that there are special procedures, tools or black magic involved. I am here to tell you that I have shortened dozens of driveshafts this very way, and very very few have needed to be balanced.
The car I am working on had no driveshaft at all, so I went to the driveshaft vault and found a suitable core. In this case it was a Ford driveshaft out of an un-known vehicle, but it was a 3" O.D. shaft that had 3 1/4 yokes that would accept 1 1/16" U-joint cups, which is what I would be using. I inspected it for dents and rust or any other damage and deemed it suitable for shortening.
The first step is to measure for the new driveshaft. The procedure I use is to push the slip yoke all the way into the tranny, and pull it out 1 1/4":
With the weight of the vehicle on the springs, I measure from the flat of the rear end yoke:
.......to the center of the front U-joint. In this case the measurement was 51 1/2":
We now need to cut one of the yokes off. I try to cut opposite of the balance weights if I can. I grab my 4 1/2" angle grinder with a thin cut off wheel and cut the edge of the weld towards the center of the shaft. You need to cut only as deep as the tubing is thick so in our case, slightly more that 1/16". It is better to cut a smaller amount than needed than to go too deep:
With the cutting done, the yoke should come right out with a couple of taps of the hammer. If it does not come out, you need to cut a little deeper:
This is the yoke after is is out of the shaft:
We now need to shorten the tube. The shaft I was cutting was 56 " center to center, so 4 1/2" would need to be cut off. I use a thin wall tubing cutter because it cuts perfectly straight. You could use a cut off saw, but make sure that the cut is perfectly square:
Here is the tube after the cut and after de-burring with a file:
The yoke can now be tapped in to the tube and the center to center measurement adjusted. I like to leave about 3 /32" of a gap for welding into. I also place both flats of the end yoke on a flat surface to make sure that they are both in the same plane. You can adjust the yoke wherever you want it with a couple of hammer taps:
The front U-joint and yoke can now be installed, as well as the back U-joint. The driveshaft can now be bolted into the vehicle. At this point you might be thinking,"He forgot to weld the yoke on." I didn't forget, I do this so I can check the run out with a dial indicator. I mount a dial indicator on the rear end, and set it against the drive shaft tube to measure the run out. You can now adjust the run out with a few well placed hammer taps. I try to achieve the smallest amount of run out possible, in this case about .004" which is pretty good. With the driveshaft still bolted in the car, I tack weld it in four places:
The driveshaft can now be removed from the car in order to be welded. I would strongly suggest that you have at least a 185 amp MIG welder for the next step. If you are not comfortable with your welding skills, take it to someone who is qualified to weld it:
A little paint, and we now have a finished driveshaft. As I said before, I have shortened dozens of driveshafts just like I describe, and only a few have needed to be balanced, but even if you need one to be balanced, you have saved a considerable amount of money shortening it yourself:
Old Jan 24, 2011 | 10:20 AM
kalli's Avatar
kalli
nice article. ya. the runout is important. probably the reason I never did it. in hindsight after reading your article, I'm pretty sure I'll tackle it at some stage when the next one comes along who needs shortening
Could always do the fabrication part myself and when done bring it to shop for welding.
for the original poster: if you absolutely don't want to fabricate change or look for anything, contact dennys driveshaft. you will just need to measure a few things and they'll make you a new one. other than that you can always get a driveshaft from that year and see if it fits/and or modify to your needs
Old Jan 24, 2011 | 10:47 AM
jspagna1's Avatar
jspagna1
Here ya go..............
http://www.dennysdriveshaft.com/
