Engine upgrade for my 1965
Old Feb 1, 2011 | 10:11 AM
  #21
Dennis Marks's Avatar
Dennis Marks
Originally Posted by 001mustang
Cast Iron vs Aluminum. CI is cheaper, heavier, and more durable.
Most small block ford (sbf) heads have rectangular ports but some companies like Hedman have oval ported headers that will leak. I would use only ceramic coated thick flange stainless steel headers. You won't miss a few horses but you can't miss a leaky rusty header.
If valve train noise bothers you be very careful w/ roller rocker selection.
Thanks for the info and clarification. Like I said 40 years out makes it difficult plus I used to build Chevy's in my car days. Few options back then.
Old Feb 1, 2011 | 10:57 AM
  #22
frdnut's Avatar
frdnut
The early blocks(late 60s early 70s) are supposed to be a little stronger but if you have a good running 1980s motor I don't think its worth swapping it just for block strength alone...Even if you buy a crate motor it will likely have a similar block..If you are wanting the ultimate in block strength you will have to pay for an aftermarket block which is not a bad idea if you are making well over 400hp..
If your only looking for around 325hp I don't think its a big concern..You can get that with a good set of aftermarket heads,camshaft and intake...
Old Feb 1, 2011 | 12:53 PM
  #23
Dennis Marks
Thanks for the info. Fast car. From what I have read it seems AFR makes about the best heads but they are $ and I really don't know if they will produce the increases they say. I still have no clue on the cam.
Last edited by Dennis Marks; Feb 2, 2011 at 08:28 AM. Reason: needs to be a capital etter
Old Feb 1, 2011 | 01:03 PM
  #24
001mustang's Avatar
001mustang
Default Choosing Cam
Decide engine longevity goal; 100,000 miles, 20,000 miles, 500 miles, 5 miles.
Decide valve train noise level you can live with.
Decide your engine RPM red line.
Count money in your wallet.
Old Feb 1, 2011 | 01:06 PM
  #25
eZ's Avatar
eZ
my two cents...I would opt for an edelbrock power package. All the thought and worries you have expresed have already been thought out for you. AFR heads are great (I have them) but the componets they come with suck, their threads are too soft and strip like crazy. Ive had to helicoil all the header threads. Edelbrocks already come helicoiled.
http://www.edelbrock.com/automotive_...tek_ford.shtml
Old Feb 1, 2011 | 01:08 PM
  #26
eZ's Avatar
eZ
Can you elaborate on this one?
Old Feb 1, 2011 | 03:20 PM
  #27
001mustang's Avatar
001mustang
Long story.
Could waste a good crop getting to bottom of valve train noise level vs components used.
Valve train noise complaints even spill over to performance OEM cars.
Roller rockers (cheap and expensive) have many pulling hair over the loud sewing machine racket heard over exhaust note.
I have several videos of racket making roller rocker cars.
If I won lotto I would get shaft rockers w/ 1.5 ratio.
Attached Thumbnails Engine upgrade for my 1965-0-shaft-rocker.jpg   Engine upgrade for my 1965-0-shaft-rockers.jpg
Old Feb 1, 2011 | 03:35 PM
  #28
Dennis Marks
Thanks a lot. Good info. That sounds like a good start that will eliminate many of my questions. Package deals take a lot of the guesswork out. Nice car. Thanks again
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
mdj89
Sep 6, 2015 11:08 PM
zachary1988
Sep 4, 2015 03:04 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
