transmission swap
Old Feb 2, 2011 | 07:38 PM
ColtonS3290's Avatar
ColtonS3290
Default transmission swap
I have a 1969 351w i took the transmission in in, which is a 3 speed i couldn't tell you what model off the top of my head, but they want to much money to repair it so im considering swapping out for another transmission but now sure what all i will need to do it, i've heard you can put a T5 in with a positioning plate or something and i was also told you need to get a clutch pedal adapter, i've also heard of a toploader 4 speed i think it was called but the thing is i only have a 400 to 450 dollar limit on money to spend. so any kinda help would be much helpful.
Old Feb 2, 2011 | 08:15 PM
mortman's Avatar
mortman
Yo can pick up a T5 for about 500.00, but obviously you will want to make sure its in good shape so an inspection/rebuild adds to the price. Then the adapters or machine work for the bell housing (250.00) as long as your drive shaft fit up your good, other wise even more.
T-5 info http://www.fordmuscle.com/archives/2...p/index2.shtml
swap info http://www.fordmuscle.com/archives/2...swap/index.php
Also there is an excellent thread here i just cant find at the moment
Old Feb 2, 2011 | 10:39 PM
andrewmp6's Avatar
andrewmp6
A t5 would be better its a overdrive trans but you will need a crossmember to hold it you can buy one or make one.Talk to http://www.moderndriveline.com/ he can sell you everything you need.
4cylinderplus2
Oct 9, 2020 07:45 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
wraith777
Sep 28, 2015 10:49 AM
