Brake upgrades
Old Feb 8, 2011 | 02:59 PM
BeastMachine67's Avatar
BeastMachine67
Default Brake upgrades
Hey guys, does anyone have any sugguestions for a front disc brakes upgrade that wont break the bank? Even if If it's from a donor car? I already have disc brakes in the front
Old Feb 8, 2011 | 03:40 PM
greystallion66's Avatar
greystallion66
I am using the sbc set up. I thought it was reasonably priced, and it was easy to install.
Old Feb 8, 2011 | 06:10 PM
chockostang's Avatar
chockostang
Yes indeed, the SSBC conversion is a excellent setup, a couple hundred higher than the cheaper made brakes, but well worth in quality differences.
Dan @ Chockostang
Old Feb 8, 2011 | 07:00 PM
Starfury's Avatar
Starfury
What's wrong with the brakes you have? I have the factory KH brakes on my car and I don't see any need to upgrade them. There's definitely no shortage in stopping power.
Old Feb 8, 2011 | 07:14 PM
chockostang
I stand corrected Star. I Mis read the question.
Yes if the present Disc Brakes are Factory K/H, then they are GREAT brakes.
To Change to a "Foreign" system is not a wise idea to gain braking, he already has them.
Update to new specs, Cruise.
Thanks for see that Star.
Dan @ Chockostang
chockostang
Thanks for seeing that Star.
Dan @ Chockostang
Old Feb 9, 2011 | 07:57 PM
BeastMachine67
one of my brake calipers is staring to stick so, I guess I figured rather than replacing it or rebuilding, I'd just upgrade to a 2 piston caliper or something..
Old Feb 10, 2011 | 01:50 AM
andrewmp6's Avatar
andrewmp6
The only upgrades i know take a 17 inch rim are you willing to buy new rims?Cheapest would be to rebuild the brakes you have now.If you have the 4 piston calipers there's not much of a upgrade tell you get in to the bigger brakes that take a 17 inch rim to clear.
Old Feb 10, 2011 | 08:26 AM
Starfury's Avatar
Starfury
Exactly. A 2 piston caliper is a downgrade from the OE 4-piston disc brakes. Rebuild kits are available for your calipers and will cost you a fraction of what you're considering spending.
Old Feb 10, 2011 | 09:57 AM
blue66mustang's Avatar
blue66mustang
What he said..
