Help, trying to replace front brake hose
Old Mar 6, 2011 | 10:27 AM
five-gs's Avatar
five-gs
Default Help, trying to replace front brake hose
Hi, I have a 66 Mustang 6 cyl with drum brakes. I am trying to bring it out of the garage after many years. I have replaced the wheel cylinders brakes and hardware. I also put in a new master cylinder. I can not figure out how to remove the upper part of the flexible brake line (front). any help would be great.
Old Mar 6, 2011 | 11:39 AM
001mustang's Avatar
001mustang
pull out the clip 1st.
those nuts can be a bear.
line wrench sometimes not enough and will strip flats off.
in bad case i have to use very tight vise grips.
Old Mar 6, 2011 | 11:59 AM
2+2GT's Avatar
2+2GT
Yeah, a wrench on the hose end, and a flare nut wrench on the steel end. If the nut seems corroded, there is one way to loosen it, but I hesitate to suggest it.
Old Mar 6, 2011 | 12:15 PM
001mustang's Avatar
001mustang
sounds scary
Old Mar 6, 2011 | 04:01 PM
five-gs's Avatar
five-gs
ok had to use crescent wrench. hard line came off (that's a start) but still no idea how to remove flexible line
Old Mar 6, 2011 | 04:09 PM
2+2GT's Avatar
2+2GT
Huh? Pull the C clip and it'll fall off.
Old Mar 6, 2011 | 04:11 PM
five-gs's Avatar
five-gs
thought that was it, but i guess i need to pry a little harder.
Old Mar 6, 2011 | 04:17 PM
five-gs's Avatar
five-gs
GOT IT!! Thanks for the help :-)
Old Mar 6, 2011 | 04:21 PM
001mustang's Avatar
001mustang
good.
sometimes those nuts are so frozen the line will twist w/ the nut.
gives a good excuse to buy new lines though.
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Calizic
Aug 28, 2015 01:46 PM
bond007
Aug 26, 2015 11:36 PM
Tyoung68
Aug 25, 2015 04:31 AM
cvarner131
Aug 17, 2015 07:38 AM
