front shock mount
Old Mar 12, 2011 | 10:58 AM
hotrod351's Avatar
hotrod351
Default front shock mount
while putting new tires on my 70 i noticed the right side bottom shock mount had the rubber pushed out of it. im talking about the mount that mounts to the top of the upper control arm. i know ill have to compress the spring and remove the shock to fix it but will a new bushing affect the alignment.
Old Mar 12, 2011 | 12:04 PM
Gregski's Avatar
Gregski
the short answer is yes, and here's why, first of all you should replace the bushing on both sides even though the other side seems fine, it's the same concept as doing brakes you don't just do one side. Second in order to get to the bushing you will be taking things apart, it is the taking of things apart and putting them back together that warrants an alignment, for an alignment I would recommend finding a shop that has done a classic mustang or two, and not your pimple faced Pep Boys techies, (no offense to pimple faced boys out there, lol)
Old Mar 12, 2011 | 12:29 PM
67mustang302's Avatar
67mustang302
I'd find a shop that actually understands alignment, like a race car chassis builder.
Understanding alignment and doing alignment are completely different things.
Old Mar 12, 2011 | 01:05 PM
hotrod351's Avatar
hotrod351
well now i need to find out what the bushings all called and where to find them. checker and autozone dont show them.
Old Mar 12, 2011 | 01:14 PM
2+2GT's Avatar
2+2GT
If you want only the bushings, you can get them from Glazier/Nolan, p/n G05116 $16, but they must be pressed into your old saddles. If you don't have access to a press, get the whole saddle, p/n G05014 $25.
Old Mar 12, 2011 | 02:40 PM
67mustang302
I'd just get the whole saddle, since the rubber insular the spring rests on is likely tore up as well.
Old Mar 12, 2011 | 05:05 PM
2+2GT's Avatar
2+2GT
Originally Posted by 67mustang302
I'd just get the whole saddle, since the rubber insulators the spring rests on are likely tore up as well.
Funny thing, the replacement saddles come with these, but the originals didn't. Which is why they usually aren't there on beat-up old Mustangs.
Old Mar 12, 2011 | 06:47 PM
67mustang302
Haha, didn't know that. Mine had beat up ones, but I suspected stuff had been replaced.
Old Mar 13, 2011 | 07:36 AM
hotrod351's Avatar
hotrod351
well like a lot of things the hard part was finding out what there called. finally figured that out and found them at a few places. figured it would be best to replace the whole part, cheap enough.
Gene K
Oct 21, 2015 11:37 PM
guitarman376
Oct 11, 2015 01:47 AM
67STANGX2
Sep 24, 2015 12:29 PM
Sep 16, 2015 07:53 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
