66 Ignition Cylinder
So I was letting my carb soak so I could get it cleaned up and decided to put in the new ignition cylinder. I got the old one out fairly easy considering I had no key. But when I went to put the new on it wouldn't go in. I compared them and they are slightly different.
The one on the left is the new one. It has that third piece sticking out. Looking in the dash I can see it has the third one, but, the label cover doesn't have that gap for the new one to go in. My question, before I go any farther; Has anyone else seen this and is it possible to get it in or is it the wrong one?
If you mean it needs to have the pin pushed and it rotated past that I did do that. It phyiscally will not go past the housing. I contacted CJ Pony and tey are looking into it. It is a Scott Drake part, first I've used. Think I understand the thread last week very well now. This scares the heck out of me as there will eventually be alot of things replaced and it seems they are the only ones make parts.
bradleyb
Nov 27, 2015 07:50 PM
