engine running hot.
Old Aug 26, 2005 | 11:10 PM
67_FASTBACK's Avatar
67_FASTBACK
Default engine running hot.
hmmmm.... today i took my 289 67 fastback out for a drive for about 5-6 mintues just on some city streets, only goin like 25-30 mph at most, and for some reason it is overheating bad. i opened the hood and it was smoking out the cylinder heads, the radiator and the whole general engine. does it have something to do with me running it on water in the radiator. i put some in before i drove cuz it was low. ps, my transmission was actin' funny too, it lagged between shiffting into 2nd gear, could that have sumthin to do with the overheating as well? thnx.
Old Aug 26, 2005 | 11:58 PM
68COOP's Avatar
68COOP
Default RE: engine running hot.
Sounds like you are in dire need of a flush, or your bottom hose is sucking closed because it don't have a spring in it.
Old Aug 27, 2005 | 07:37 AM
Soaring's Avatar
Soaring
I ♥ Acer
While the engine is cold, take the thermostat out (then replace the thermostat housing) and take the radiator cap off and turn on the engine. With a garden hose, keep putting water in the radiator until it overflows. Keep doing that until the radiator will not take any more water. Then, put the cap back on and see if it overheats. If it does not, then you need to replace the thermostat. If it does, then you have other issues such as a plugged radiator or a water pump that has gone south. Let's just hope you don't have a blown head gasket or a cracked block.
djbigskrilla
Sep 20, 2022 01:04 AM
Gary Ugarek
63
Dec 11, 2015 02:01 PM
Gary Ugarek
Sep 5, 2015 09:03 PM
ShaneB26154
Aug 28, 2015 04:47 PM
HIS S-197
Aug 10, 2015 05:47 PM
