Redline on 347?
Old Mar 25, 2011 | 01:59 PM
FoMoJoe's Avatar
FoMoJoe
Default Redline on 347?
Adjusting my tach here...
What's the redline on a 347?
Old Mar 25, 2011 | 02:18 PM
hightower2011's Avatar
hightower2011
Probably between 6,000-7,000 rpm. Lots of variables depending on your engine specs and whatnot. Probably want to Dyno it to find out for sure.
Old Mar 25, 2011 | 02:39 PM
Iskwezm's Avatar
Iskwezm
I used to turn mine to 7200 before the turbo. My buddy turns his to 7800, so it depends on your build.
Old Mar 25, 2011 | 03:15 PM
scott_m_mil's Avatar
scott_m_mil
Run it until it quits pulling, and then place the redline a few hundred rpm's below that to compensate for clutch time.
Old Mar 25, 2011 | 04:46 PM
67mustang302's Avatar
67mustang302
Depends on how it's built. Anywhere from around 4,500rpm to 10,000rpm.
What crank/rods/pistons and what lifters/pushrods/rockers/springs? And what block?
Old Mar 25, 2011 | 11:06 PM
sethalot's Avatar
sethalot
^ what he said, valve train is usually the limiting factor
Old Mar 26, 2011 | 12:31 AM
PaulS's Avatar
PaulS
What cam do you have? You want to set the red line where your engine makes peak power.
Old Mar 26, 2011 | 03:40 AM
67mustang302
Provided it holds together, but sometimes a bit after peak power.
Old Mar 26, 2011 | 11:50 AM
frdnut's Avatar
frdnut
+1.....Like stated it depends on the valve train and the componants in the bottom end to how high you can physically rev it before it grenades itself..How well the engine breathes will determine where it stops making power..
JoshyGT
Sep 19, 2017 08:52 PM
Brett Ludlow
Sep 23, 2015 06:59 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
