Advice on cam, intake, and head combo
Don't forget that is a roller camshaft..You can't compare new roller cams with ancient flat tappet stuff from the 60s...His car has a 3.90 rear gear and a 5 speed trans so I think it will work well for a spirited driver..
My camshaft has over 250 degrees duration at .050(advertised specs mean very little) and close to .700 lift and it idles just fine..With a 4:11 rear and a 4 speed I can putt around town with no problems at all..
[QUOTE=eZ;7481816]where does your exhaust exit the car? What front coil-over are you going with?[/QUOTE
I have no idea what coil over I am going to use. That is my next project. This engine stuff has taken me forever to get halfway knowledgeable about. I am open to suggestions but I haven't even read one thing about them yet. I am really new at this and learning as I go. I built cars in the 60's and times have changed greatly. As far as exhaust they come straight out the rear. Any ideas of anything or any way to find where the fumes are coming in? My wife refuses to ride with me until they are gone.
Your cam will give you a "lumpy" idle but it is streetable. The overall package (carb, intake, cam, heads) are matched for the same rpm range so they will work together well but you will suffer some loss of low rpm and a loss of mpg.
I didn't notice any mention of headers - and you will need some headers to make the rest work well. A well thought out exhaust system will add to your performance.
If your pipes run right out the back and you have no exhaust leaks I would check your trunk rubber..The mustangs are bad for sucking in fumes around the trunk lid area..It's probably not coming from the engine compartment..
The Rhoads lifters bleed down at idle and low rpms so that you don't have full lift..This gives the engine better vaccum and low speed characteristics with a very large cam..I don't think they are necessary in your case..Especially if you like the lope sound at idle...My brother had them in his car and replaced them because he did not like the constant ticking sound that these lifters have and much prefered the lope sound...I am not even sure if they are available in a roller lifter?
Yes PMed you back. If your exhaust exits out the back make sure your trunk lid has a good seal. Also when you dynomat the trunk floor should help. I think your biggest problems would come from not having good weatherstripping for the lid. Also make sure the car is not running rich.
