What's different about these brake pedals?
Old Mar 30, 2011 | 08:19 AM
Coupe's Avatar
Coupe
Default What's different about these brake pedals?
I'm swapping over to a different pedal assembly with a t5 swap and I noticed that the brake on the one I'm installing will pull away from the firewall further than the original unit.
It looks like the brake lever stop is different and I am concerned that the brake pushrod could fall out of the master cylinder after my disk brake swap.
Should I modify the stop on the replacement unit?
Old Mar 30, 2011 | 09:48 AM
69mach1377's Avatar
69mach1377
Power vs. non-power?
Different years also had different lever arms...
Old Mar 30, 2011 | 11:54 AM
Coupe's Avatar
Coupe
Well, they are both the same year, I guess it's possible that they came from a 67 with power brakes but I was told they were from a 65/66 when I bought em, power drum brakes in 65? I can't remember when power boosters became available?
My concern is the push rod falling out of the dual bowl mc that I will use in the swap, do those pushrods stay in the mc?
Old Mar 30, 2011 | 12:48 PM
buening's Avatar
buening
I'm pretty sure the following link will help you figure it out http://www.mustangsteve.com/fyi_brak...akepedals.html
The one on the left looks like a 67 manual brake pedal and the one on the right looks like the 65/66 power and manual brakes (same pedal)
I wouldn't install the 67 on a 65 because the M/C could get overextended if you happen to catch your shoe beneath the pedal (or something similar happens). The 65 has a bumper that prevents this, and the 67 has a different pedal hanger to account for the different pedal stop lever length.
Old Mar 30, 2011 | 03:32 PM
Coupe's Avatar
Coupe
Well, I guess I can either weld on a stop or just use the brake pedal from the automatic and cut the pad down, that may be the easiest thing to do.
Old Mar 30, 2011 | 05:06 PM
67t5ponycoupe's Avatar
67t5ponycoupe
There is a clip that holds the rod into the master cylinder so if is properly installed it won't fall out. You have to use the rod from the 65/6 on the 67 master to make it work right.
Old Mar 30, 2011 | 05:23 PM
2+2GT's Avatar
2+2GT
No, it's not a 67. It is later, though, the one with the rubber bumper is an early unit. The clip in the tip of the pushrod is supposed to keep it in the master cylinder. Power boosters were available from day one. 64-66 power brake used the same pedal as standard brakes.
Old Mar 30, 2011 | 07:40 PM
Coupe's Avatar
Coupe
22, do you think its a late 65 or a 66? The carrier is identical to my 65 (the one on the right, it is my existing setup).
I wonder how trustworthy that clip is in reality? If it fails the pedal on the left could get you killed?
I am taking it apart for a bearing kit on the clutch anyway, so I guess ill just use the pedal with the stop from my existing unit and cut down the foot pad.
Old Mar 30, 2011 | 07:44 PM
chockostang's Avatar
chockostang
I,ve never seen a tab welded on the pedal as the one on the left. I'm sure a Hookie Pookie setup there.
Both are NON Power pedals, For Non Power setups.. No Booster fits these pedals--Factory anyway. A Bunch of Force fit will.
Power Disc require a different pedal with greater leverage.
The Clip thing, Yes. If you have Manual brakes, the master will have a recessed/machined area in the every bottom of the piston. The push rod clip ring flips out into this area, making the push rod fixed in the master.
If no machined area, Not a correct master for push rod application---Yes a wreck about to happen.
Dan @ Chockostang
Old Mar 30, 2011 | 07:55 PM
2+2GT's Avatar
2+2GT
Typically, a small sledgehammer is required to get the shaft out of the cylinder. I don't worry about it falling out, I worry about getting it out. From 66 on, that was all Ford used to keep then together.
