Distributor Timing?
Old Apr 1, 2011 | 04:19 AM
wonso79's Avatar
wonso79
Question Distributor Timing?
What can cause your distributor timing to change? I recently took out the points and condensor and switched it to a pertronix ignition, could that change the timing?
Old Apr 1, 2011 | 06:02 AM
2+2GT's Avatar
2+2GT
Sure. Changing the dwell changes the timing. If your dwell wasn't perfect before, it'll definitely have different initial timing now.
Old Apr 1, 2011 | 10:08 AM
frdnut's Avatar
frdnut
I believe it tells you right in the pertronix instructions to check your timing after the install..
Old Apr 1, 2011 | 11:00 AM
boeing747arowair's Avatar
boeing747arowair
Yes it does!
Old Apr 1, 2011 | 11:04 AM
kalli's Avatar
kalli
ya. the exact moment the points open it will cause the coil to fire. so if the points are getting older it usually causes them to wear off at the contact plate, that causes them to open sooner. to avoid all that crap you install the pertronix. but once you do you have to adjust ignition. good news, once you do it it should 'stay' now
Old Apr 1, 2011 | 03:48 PM
wonso79's Avatar
wonso79
Yes must of missed that step on the instructions! LOL thank god nothing blew up or anything! Thanks everyone!!
carid
Jul 8, 2016 09:55 AM
mungodrums
Oct 7, 2015 04:01 AM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 11:50 AM
