Good Information
Old Aug 27, 2005 | 08:45 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default Good Information
http://www.proracingsim.com/desktopdynobasic.htm Thanks goes to Dan Aranda.
Old Aug 28, 2005 | 02:32 PM
69mach1377's Avatar
69mach1377
Default RE: Good Information
No problem...just remember, these tools are not absolute. They are better used to determine the relative effects of changing the parts or settings (parameters).
For example, I ran the new Edelbrock 351C heads to gain only 40hp over my existing setup, while taking the CR from 9.9 to 12.8 to 1. Now its not even streetable and they cost about $2k to buy. Not worth it in my book....
Old Aug 28, 2005 | 05:06 PM
Soaring's Avatar
Soaring
I ♥ Acer
So, what are you saying Dan? Is this software a good buy or not? Not having experience with this software, can I tell it I want 400+ RWHP and it will tell me what add-ons I need to achieve that?
Old Aug 29, 2005 | 01:12 AM
69mach1377's Avatar
69mach1377
If anyone is going to spend 2-4k on a new engine, this is definitely worth it. It will help you figure out what you need to get what you want.
In my example, I found out I would have to spend 2k for just 40 more horsepower. I just saved 2k...
You begin by baselining what you have, then change the cam or whatever, and it will tell you the effect of your changes. Or you can start from scratch to come up with the combo that works best for you.
DEFINITELY WORTH IT!!!!!!!!!!!!
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
mungodrums
Oct 7, 2015 04:01 AM
Sparks_88
Sep 8, 2015 01:06 PM
TimeLord101
Sep 4, 2015 09:27 AM
