pcv
Old Apr 6, 2011 | 11:28 AM
kalli's Avatar
kalli
Originally Posted by 1971mach1
New air has to come from somewhere to replace the vacuum.
Some sentence that is :-)
however I'd nearly say a PCV would operate without a breather. haven't tried it, but as far as I know it only opens when there is pressure in crankcase causing the intake to pull it out. no pressure->no operation. there should never be a vacuum in the crank case. and if there is no pressure in the crank case the PCV should not open for the intake to pull. otherwise you don't have a PCV but a massive vacuum leak
Kalli
Old Apr 6, 2011 | 11:33 AM
mr_velocity's Avatar
mr_velocity
Kalli
Some of the old school drag guys ran a vacuum pump for the crank case to keep it under vacuum. I'm still researching this whole deal, I would like to run pcv without a breather, still not sure if its possible or not.
Old Apr 6, 2011 | 12:55 PM
jc92073's Avatar
jc92073
I had the same problem on my 1967, I tried a couple of different brands, some worse then others. Got a Motorcraft PCV for a 1994 5.0 and the noise is gone. It is plastic and has a 90 Degree adaptor that pops off you if just want the fitting that faces up.
Old Apr 6, 2011 | 01:55 PM
1971mach1's Avatar
1971mach1
Kalli
A PCV definatly needs a breather to let in fresh air. A PCV is more of a controlled vacuum leak, not massive.
If your breather has a tube connected to the air cleaner, it's considered a "closed system" because even if bad gasses back up into the air cleaner, they get sucked down the carb. It does work with just a filtered breather cap though (if the filter is not clogged).
It's a great system if it's setup right (with a breather) and it doesn't affect performance.
A detailed overview of how the PCV works and it's history is at:
http://en.wikipedia.org/wiki/PCV_valve
Old Apr 6, 2011 | 10:26 PM
mikenkiki05's Avatar
mikenkiki05
jc someone told me about running one from a efi 5.0 we are stalled on the car right now as we are moving next month (just down the road) 8 miles thats it lol so wife says no more money on mustang, she is just saying drive it like it is until oct then pull it out and bore and stroke it
btw what can a 289 be stroked out to? and bored out too? lol
Old Apr 6, 2011 | 10:56 PM
mikenkiki05
http://www.flickr.com/photos/6148893...n/photostream/
Last edited by mikenkiki05; Apr 6, 2011 at 11:00 PM. Reason: couldnt get pics to upload so i made a flicker account
Old Apr 6, 2011 | 11:06 PM
mikenkiki05
there is the website where the pics can be seen they are not that clear i took them with my phone but still can see the pics real well
Old Apr 7, 2011 | 11:45 AM
frdnut's Avatar
frdnut
+1......Open breather on one valve cover and PCV in the other...
Old Apr 7, 2011 | 01:30 PM
MustangFTW
Guest
Posts: n/a
the breather is the oil cover thingeh too right?
Old Apr 7, 2011 | 01:56 PM
boeing747arowair's Avatar
boeing747arowair
thats correct on my six banger the one closer to the radiator
JonnyBlazeGT
Nov 3, 2015 01:10 AM
lmurf60
Sep 24, 2015 10:07 PM
Ipaman
Sep 22, 2015 07:01 AM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
