289 build
Old Aug 28, 2005 | 12:02 AM
6mustang6's Avatar
6mustang6
Default 289 build
My dad and I are planning on rebuilding his 289 soon. How much power can it hold? I think we might put a stroker 306(does it fit?) , aluminum heads, intake, new carb, cam, and a new exhaust system. Can a 289 block hold this much power and if so, what is a guesstimate at the HP ratings.
Old Aug 28, 2005 | 02:25 PM
69mach1377's Avatar
69mach1377
Default RE: 289 build
A 302 is stroked 289, same type block I think. Should hold 300-350 hp using quality machining, parts and fasteners.
Old Aug 28, 2005 | 02:55 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, it's the same block. So much depends on what you add to the top of the pistons. As Daniel pointed out, getting over 300 HP from a 289 is doable.
Old Aug 28, 2005 | 05:04 PM
6mustang6's Avatar
6mustang6
thanks guys, So a 306 stroker kit will fit? Im sure it would, but wanted to be sure about it.
Old Aug 28, 2005 | 08:04 PM
69mach1377's Avatar
69mach1377
Basically you are sticking a 302 rotating assy into your 289 block that is .030" overbored, no problem.
Old Aug 28, 2005 | 09:20 PM
6mustang6's Avatar
6mustang6
Ok, thanks alot!
uberstang1
Dec 7, 2017 07:10 AM
svfetter
Oct 5, 2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
GTJIM
Sep 23, 2015 09:59 AM
ryland
Sep 13, 2015 12:35 PM
