Cable Clutch Issues
Old Apr 12, 2011 | 01:48 PM
AscolA's Avatar
AscolA
Default Cable Clutch Issues
Hey All,
About a year ago, I did a t5 conversion with at Mustang Steve Cable. It was supper hard to shift, so I made an adjustment at the clutch fork. After some trial and error, I got it shifting well. However, in the higher gears 3, 4, 5 it seems as if the clutch is half engaged, and when I step on the gas the rpms shoot up (like my foot was lightly pressing in the clutch) and then after a few seconds the car starts to accelerate. I don't think this was an issue when it was hard to shift. Has anyone else had similar issues? Also on the mustang steve site it appears as though you can adjust the cable at the firewall- anyone know if this is the case? Any suggestions or info would be great.
Thanks in advance.
Old Apr 12, 2011 | 04:03 PM
PaulS's Avatar
PaulS
What you seem to be describing is a slipping clutch. The reason it is more noticable in the higher gears is because the lower gears allow the car to accelerate with less engine torque.
Old Apr 13, 2011 | 08:32 AM
AscolA's Avatar
AscolA
Sorry if this is a stupid question, but what would cause the clutch to slip? It has about 500 miles on it.
Old Apr 13, 2011 | 01:17 PM
AscolA's Avatar
AscolA
So I had a guy do the t5 swap. He was supposed to resurface the flywheel, but I have know way of knowing if he did. Would this cause a new clutch to slip?
Old Apr 13, 2011 | 05:40 PM
scootchu's Avatar
scootchu
Either a worn clutch disc or a contaminated disc would cause slipping, but if you adjusted the cable it might just be that the problem surfaces in higher gears because the throwout bearing is still engaging the Pressure Plate. It might be too tight and not allowing the bearing to release and apply full pressure to the clutch disc.
Old Apr 14, 2011 | 10:48 AM
AscolA's Avatar
AscolA
Yeah- thats what I was thinking was happening. But if I adjust it too much, I have a hard time shifting.
Does anyone else have a Mustang Steve Cable? Can it be adjusted at the firewall?
Old Apr 15, 2011 | 04:10 AM
tx65coupe's Avatar
tx65coupe
You don't want the cable adjusted too tight with preload on the bearing.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
PNYXPRESS
Sep 14, 2015 09:50 PM
MasterLanMan
Sep 13, 2015 08:21 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
Emblazoned
Sep 3, 2015 10:45 PM
