Door post?
Old Aug 28, 2005 | 10:09 PM
pak133's Avatar
pak133
Default Door post?
I've found all the parts I need to repair my newly purchased 1965 Mustang except the door post. It's the section of the door jam that the door pin screwes into. It's dented and needs to ne replaced. Is there a proper name for this body section that I should use to look up the part? Thanks.
Phil
Old Aug 29, 2005 | 12:53 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Door post?
I have no idea where you can find that part. You might need to take it to a body shop to have straightened.
Old Aug 29, 2005 | 01:03 PM
pak133's Avatar
pak133
I think you're right, either a body shop or maybe I can cut the peice out of another car and do some welding.
Thanks.
Old Aug 29, 2005 | 01:38 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, if you have the welder and the skills, that is exactly what I would do. But you may be hard pressed to find another car with that same configuration, so may have to get inventive.
Old Aug 29, 2005 | 01:40 PM
pak133's Avatar
pak133
That's why it's called a project car
P
Old Aug 29, 2005 | 02:06 PM
Soaring's Avatar
Soaring
I ♥ Acer
Welcome to the world of restoring old Mustangs. Have fun!
baddog671
Jul 26, 2016 01:20 PM
b8checker
Oct 8, 2015 12:55 PM
Explosive
Oct 2, 2015 07:45 AM
b8checker
Sep 30, 2015 07:11 AM
Sep 25, 2015 06:58 PM
