Disc Brake conversion on Inline 6??
Old Apr 26, 2011 | 04:43 PM
wonso79's Avatar
wonso79
Question Disc Brake conversion on Inline 6??
Has anyone done a disc brake conversion on there inline 6 and if so what brand of brake conversion kit did you go with? Does anyone know of a good disc brake kit that is good quality but not top expensive?
Old Apr 27, 2011 | 12:55 AM
andrewmp6's Avatar
andrewmp6
Only two kits i know of are http://www.ssbrakes.com/ and http://www.abspowerbrake.com/
Old Apr 27, 2011 | 10:52 AM
2+2GT's Avatar
2+2GT
I'd give real serious consideration to the Scarebird kit. VERY inexpensive, uses stock parts available anywhere (except for the Scarebird brackets) and you get to keep the stock wheels you have now, if you want.
Old Apr 27, 2011 | 03:54 PM
wonso79's Avatar
wonso79
Thanks for the info guys!! If I wanted to do a 5 lug conversion what would I need other then a new rear end and front spindles and of course a V8 disc brake conversion?
Old Apr 28, 2011 | 12:14 AM
degins's Avatar
degins
If you intend to use 5 lug V8 spindles then you should upgrade the steering linkage to V8 spec as well. The geometry of the manual 6 cylinder linkage is not optimal for these spindles. The new linkage includes a pitman arm, center link, idler arm and bracket, inner and outer tie rods, and tie rod adjusters.
There are several options for converting the 6 cylinder car to disc brakes. Any conversion to 8 cylinder spec will require a spindle change. Most, if not all, of the conversions that use the existing undersized 6 cylinder spindles have 10" rotors.
Old Apr 28, 2011 | 12:46 AM
andrewmp6's Avatar
andrewmp6
I wouldn't trust Scarebird kit it mixs brake parts and most kits use s10 calipers,You ever drove a s10 there brakes suck trust me.5 lug swap is http://www.mustangandfords.com/howto...ade/index.html
Old Apr 28, 2011 | 01:27 AM
jp1967stang's Avatar
jp1967stang
If your looking at doing a conversion to 5 lug here is a nice kit ive used it works great and i can afford it. http://www.opentrackerracingproducts.com/discbrakes/ Most of the steering parts for v8s are pretty cheap too if running manual steering.
Old Apr 28, 2011 | 05:45 AM
2+2GT's Avatar
2+2GT
Seriously? I drove an S10 Blazer for years, thing would stop on a dime. Considering it was probably near double the weight of a 65 Mustang, I'd say that was plenty of stopping power.
The thing about the Scarebird conversion is you could do it for a few hundred bucks on a Saturday afternoon. 5-bolt conversion will cost you at least 4-5 times as much, and require a month of weekends to accomplish.
Old Apr 28, 2011 | 06:57 AM
sideshow_downs's Avatar
sideshow_downs
I just ordered this kit. I am deployed right now so i dont know how it is personally but i read alot of reviews on it before i ordered. http://discbrakeswap.com/
Old Apr 28, 2011 | 11:24 AM
jp1967stang
same one i posted i have it in my 65 works great, looks good with the sloted rotors, and has everything you need. Where you deployed to? I also had a lot of work done by my father wile i was deployed.
