347 installed today....
Old May 11, 2011 | 12:28 PM
kalli's Avatar
kalli
very clean, I like that. will the hood fit?
Old May 11, 2011 | 12:36 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Originally Posted by Rat fink
I can't view the pictures, I get this message
were you logged in when you tried to view them?
Old May 11, 2011 | 12:51 PM
Rat fink's Avatar
Rat fink
I never log out, I can see the pictures now. Before all there were was links and when I tried to click on a link it gave me that message.
Old May 12, 2011 | 02:58 AM
synthartist69's Avatar
synthartist69
Will the hood fit, good question. I will find out soon. The performer rpm intake has a spacer on top of it which is why the carb is so high. I had to do this to keep the fuel line above the intake. However, if there is a problem I will try a thinner spacer. This one is around an inch. Personally, I like the look of the air cleaner lower, like the original 289 HIPO.
Old May 12, 2011 | 03:04 AM
synthartist69
Originally Posted by frdnut
Looking good...What's the problem with the Z bar?
Well, I should have seen this before we installed the motor. The 5.0 block does not have a correct hole for the pivot that the zbar hooks to. We put the pivot in what we thought was the hole for it, but I should have known better since 5.0 rollers use cable clutches. Now I see that I need a bracket that bolts to the engine in which the zbar bolts to.
Honestly, this is the first time I heard about the bracket since my conversion began 2 months ago! The 5.0 and T5Z swap is not as easy as some make it out to be and I have found that there is not a lot of clarity by the manufacturers of parts as to what works with what.
One thing I will say for sure, the MAC LONG TUBE headers with the matching H-pipe fits like a dream! It's not too low to the ground either! It really floors me that MAC is not selling more of these...
Old May 12, 2011 | 06:18 AM
kalli's Avatar
kalli
well I have a 302 with 1" spacer and rpm intake. should be the same height so :-) all good. Only the cobra air cleaner (the long oval one) is hitting the front of the crossbrace in hood occasionally
mtgldr
Feb 3, 2024 09:00 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
