Engine Tick, Oil on plugs
Old May 12, 2011 | 02:10 PM
drummflyer's Avatar
drummflyer
Default Engine Tick, Oil on plugs
'65 200cc 6 cylinder-
My engine has been running pretty rough at idle then suddenly developed a 'tick'. So I pulled the plugs was appalled to see a couple of them swimming in oil and a couple others completely fouled. Any ideas on where the oil is coming from or what the 'tick' might be?
Old May 12, 2011 | 04:32 PM
MustangFTW
Guest
Posts: n/a
welcome to the forums, please enjoy your stay
Old May 13, 2011 | 02:07 PM
boeing747arowair's Avatar
boeing747arowair
most probably problem with the rings. do you have some pictures of the plugs. btw where are you in florida
Old May 13, 2011 | 02:49 PM
1971mach1's Avatar
1971mach1
Make sure you are getting spark on all cylinders, starting with the oily ones (the "oil" may actually be unburnt gas).
The ticking might be a spark plug wire shorting out or arcing because of a bad SP wire connection.
If spark's ok, Do a compression test to rule out rings/valves.
Old Jun 10, 2011 | 09:51 PM
Bryan B1965's Avatar
Bryan B1965
I've got the exact same problem on my 65 200cc, my water pump burned up and once I installed the new pump I was getting a lot of oil coming from the #4 cylinder. Hopefully it is just a bad piston ring and nothing too expensive
Old Jun 11, 2011 | 08:25 AM
03BottleFedGT's Avatar
03BottleFedGT
check your valve stem seals, had to replace mine on the 6 when it was doing this a long time ago
djbigskrilla
Sep 20, 2022 01:04 AM
Spiral534
Oct 6, 2015 04:31 PM
Itzjoe
Aug 26, 2015 08:15 PM
OBleedingMe
Aug 8, 2015 12:02 PM
