Clutch
Old May 18, 2011 | 07:06 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default Clutch
Ok so driving my 67 to work today I noticed something, also broke down for a bit. When I give it the gas and try to let the clutch out the car shakes like a beast, it won't do it. However, when I let it out slowly and let it catch, then give it the gas it goes smoothly. What is going on here?
Old May 18, 2011 | 09:48 PM
PaulS's Avatar
PaulS
A number of things can cause clutch chatter. oil on the clutch plate; broken center springs on the clutch plate; torn or broken lining on the clutch plate; warped clutch pressure plate or broken springs on the pressure plate; worn or missing pilot bearing; bad input bearing in the transmission; sloppy linkage or bushings on the Z-bar; bad transmission mount; bad engine mount(s) and probably a few I failed to remember.
Check the parts you can without removing the transmission first then check the rest.
Old May 18, 2011 | 10:13 PM
1slow67's Avatar
1slow67
ROTM Moderator
Well all the parts have about 10 miles on them. Only thing I haven't changed is the bushing set on the frame mount for the z-bar. I think I'm going to replace my clutch rod as well since its not the greatest.
Old May 19, 2011 | 10:44 PM
Starfury's Avatar
Starfury
Check the motor mounts
Old May 20, 2011 | 12:44 AM
Gun Jam's Avatar
Gun Jam
was your car auto or manual before the swap?
Old May 20, 2011 | 02:20 PM
1slow67's Avatar
1slow67
ROTM Moderator
Manual, its the same transmission that was behind the 6. Also it only does this in 1st gear, reverse has no problems.
Old May 20, 2011 | 02:21 PM
1slow67's Avatar
1slow67
ROTM Moderator
What should I look for? Ill check it out when I get it back from the exhaust shop.
Old May 20, 2011 | 02:49 PM
Gun Jam's Avatar
Gun Jam
check if they are broken...
It could just need some time to wear in. My t5 was a bit fussy for the first few 100 miles. If you dont remember getting oil on it when you installed it and the motor mounts are good just drive it for a while if you think the linkage from the clutch to the trans is in working order and properly adjusted.
-Gun
Old May 20, 2011 | 05:42 PM
1slow67's Avatar
1slow67
ROTM Moderator
Well checked the mounts and they are good. One thing I did notice once the exhaust was put on is there is a squeaking sound coming from the clutch area. It sounds like the throwout bearing is messed up or something.
Old May 23, 2011 | 04:26 AM
tx65coupe's Avatar
tx65coupe
Man, sorry to hear you having issues already. I'm thinking the same things as the others. Does the sound you speak of go away or change when you press in the clutch?
