Mag Wheels with Mag Lugs?
The most recent casualty to the torque gods were my rear Mag 500 wheels. The tapered lugs and studs and wheel holes are trashed. Apparently they do not like high torque applications when you actually have traction. The taper on the lugs are gone. The stud holes in the wheels are oblong, and the studs themselves are have eaten in two. I am dang lucky the back wheels did not fly off. Geez!
My buddy told me to get some drag type wheels to put my ET Streets on when I am playing on the track. Weld Racing ProStars have the shoulder style lug nuts and thick wheel flange like what I need. I wish I could find some Mag 500 looking wheels with the same setup. Do you guys know who might make some?
Here is a link to the wheel I ordered but am not thrilled with. They are great wheels, just do not look right on a classic musclecar.
http://weldracing.com/catalog/produc...147/image/275/
http://weldracing.com/street-perform...e/prostar.html
Here are the lugs and washers you use. That way the wheel cannot eat up the lug and start coming off. Weld calls them Mag style lugs, but others call the taper style lug Magnum lugs...I call them shank or shoulder lugs.
http://weldracing.com/lug-nut-4-1-2-rh-open.html
Thanks!
Thanks!
Hay, no problem, Friend of mine has 850 Foot lbs in his truck, unless your talking about a different car than the picture, that 351 doesn't have a lot of torque. That's the wrong color stripe for a Marron car.
wrong wheels also
wrong wheels also
you are about a *** on everything you post. I dont know you found your way here, but find your way out.
I wouldnt put Welds on that car unless they were the Weld 2.0.
ISK
I don't know who you think you are but whatever power you think you have, you don't. You leave. And take this giant middle finger with you. I can't help that you can't figure out that if the guy has elongated holes in his rims that his lugs are not tight, Your a dumb ash, Oh by the way, I live in Sugar Land Texas, In case you would like to talk face to face..
I thought not, Wooooooooose.
And , spell check would be good DA
Now I tightened the lugs on both back tires to 100ft*lbs. At 4400 rpm launches, when the power plants, something has got to give. Since I was running ET Streets, have a dual disc clutch, and decent rearend, what gave was the cheap Discount Tire conical lug nuts which caused the studs to eat in two and eventually to oval out the wheel holes. Yes leaving a tire loose will do the same thing, but I generally know what I am doing and the lugs were tight before heading to the track.
Now Rat Fink, please do not ever reply to one of my posts again.
Now back to topic, does anyone know of a vintage wheel with mag/shank lugs?
Iskwezm, why only put Weld 2.0 wheels on? The dang Alumastar 2.0 wheels are like $500 each while the ProStars are $250 each.
My existing Mag 500 wheels have the standard OEM thick flange. We would have to fab up a spacer or something to make the shank nuts work. That is a bit scary at 150mph.
I hate running mis-matched tires and wheels, but this is really just for the track and race events.
ISK
So your internet bad *** huh?
If you knew his car you would know what power he has,but you dont. So you just come shooting your mouth off to show everybody what a *** you are.
I ever make it to Candy Land, i will be sure to look you up at the local Piggly Wiggly ok.
