new gears
Old May 20, 2011 | 11:09 PM
05gtgreen's Avatar
05gtgreen
Default new gears
I just installed 3.80's (posi) in my mustang and now I notice that when I hit 80mph it vibrates like crazy. The gears don't make any noise before then so I am guessing that is not my problem. Could this be my driveshaft? Thanks.
Old May 20, 2011 | 11:59 PM
Iskwezm's Avatar
Iskwezm
try flipping the driveshaft 180*
Old May 21, 2011 | 12:09 AM
Gun Jam's Avatar
Gun Jam
did you happen to upgrade the trans as well at the same time?
Remember now that you have 380s the DS RPM is much higher at the same MPH
what were your old gears 2.70s?
Old May 21, 2011 | 08:33 AM
05gtgreen's Avatar
05gtgreen
I did the t5 first, and my vibration went away, now with the new gears, its worse then ever. Yes, I had 2.79 before. It used to vibrate with the auto, but not near this bad
Old May 21, 2011 | 12:18 PM
Iskwezm's Avatar
Iskwezm
you might want to get it balanced if it did it before and check the u-joints for play
Old May 21, 2011 | 01:51 PM
Rat fink's Avatar
Rat fink
Most likely the U-joint installed incorrectly
Old May 21, 2011 | 07:06 PM
Gun Jam's Avatar
Gun Jam
if that doesnt work dennys damnit http://www.dennysdriveshaft.com/
If it did it before its the same thing now driving at 80 as it would have been driving at 130mph with the 279s
Old May 22, 2011 | 10:02 AM
05gtgreen's Avatar
05gtgreen
Yes, I am pretty sure its the driveshaft, just wanted to make sure it wasn't the gears, thanks guys.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
