Alternator Warning Light?
Old Jun 1, 2011 | 06:33 PM
wonso79's Avatar
wonso79
Question Alternator Warning Light?
The last two times I started my mustang the alternator warning light came on for 2-3 seconds and then went off. Is this something to worry about? I have a new alternator less than 6 months in the car but the battery is several years old, could the battery be going??
Old Jun 1, 2011 | 06:45 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
probably the idle was low causing it to flicker...you said when you first start it so that would be my guess....
Old Jun 1, 2011 | 06:53 PM
wonso79's Avatar
wonso79
O.k. that would make sense, once I lightly tap the gas it goes away and stays away. Thanks!
Old Jun 1, 2011 | 07:19 PM
KMatch's Avatar
KMatch
Alternators rely on a minimal voltage/rpm to start charging. At low enough RPMs, the light may never go off. One kick of the gas usually takes care of this until key off. It's rarely a problem but if it's under warranty keep an eye on it as you may want to replace it if it gets worse before going out of warranty. And as mentioned - make sure your idle speed is up to snuff.
Old Jun 1, 2011 | 07:46 PM
wonso79's Avatar
wonso79
O.k. I will keep an eye on it. Just thought I ask someone with more knowledge about this. Thanks!!
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
Sep 25, 2015 09:06 AM
