pulled engine
Old Jun 2, 2011 | 01:57 PM
joe65coupe's Avatar
joe65coupe
Default pulled engine
so i pulled my engine. i had a blown head gasket. i have a 351w in a 65 coupe. so i took apart the top of the engine. when removing my heads i noticed 5 of my rockers were really loose. Im going to take the heads to a machine shop. where is a good place to buy roller rockers? and what are some things i should do to the car and engine while the engine is out. i also plan on putting a t5 trans in it.
Old Jun 2, 2011 | 02:32 PM
Iskwezm's Avatar
Iskwezm
Usually not all the rockers will be tight based on the position of the cam lobe they are on.
I usually just buy from Summit rather then go searching for parts.
Old Jun 2, 2011 | 02:41 PM
joe65coupe's Avatar
joe65coupe
yea i know but they were really loose i turned the engine and i still could move the rockers up and down. and thanks do you know any specific rocker set i should buy?
Old Jun 2, 2011 | 03:13 PM
kalli's Avatar
kalli
if the rocker is loose so you can move it up and dopwn at a time the spring should be compressed then the spring will never compress. I wonder how that engine was running ?!?! must have been a clattering nightmare if I undertstand that right.
make sure the threads they sit on are ok and the studs are not loose (the machione shop will check that for you).
for roller rockers, there's plenty like comp cams etc. just get the right ones for your engine.
and when you put it alltogether make sure you set them correctly. and replace those nuts that hold them down ...
Old Jun 2, 2011 | 03:29 PM
KMatch's Avatar
KMatch
There's a few reasons for loose rockers and the source of the problem should be found. If stud mounted, pulled studs? Worn fulcrums? Worn pushrods? Worn valve stems? Worn camshaft? Collapsed lifters? If the problem isn't found it will get worse.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
vintageaion
Sep 8, 2015 10:45 AM
zachary1988
Sep 4, 2015 03:04 PM
