1970 Power Brake Conversion
Old Jun 5, 2011 | 10:18 PM
plutopjf's Avatar
plutopjf
Default 1970 Power Brake Conversion
I have a 1970 Mustang with manual drum brakes. I am getting ready to do a complete brake job and want to convert to power brakes. I will leave the drums up front for now, but will convert later to disc. My question is do I need to change my pedals to accommodate the booster or will my pedals work.
Thank you for any advise.
Pluto
Old Jun 6, 2011 | 06:52 AM
chockostang's Avatar
chockostang
Simply put, To install a booster with proper, correct leverage, you will need to change to a new Factory Power brake pedal.
To install a "Will work" booster no pedal change. The "will work boosters will have parts-bolts-fittings-etc to make work on the non power pedal.
So, when buying a booster, if your supplier states no pedal change needed, it will be the "will work" variety.
Dan @ Chockostang
Old Jun 6, 2011 | 08:51 AM
2+2GT's Avatar
2+2GT
Rebuilt and reproduction 70 boosters are available, but the 70 power brake pedal is not. I suppose, if you can't find one, you could move or replace the connecting pin on the pedal to the correct location, which is about (don't quote me) 1/2" higher on the pedal than 67-69.
Put me down as NOT a fan of "will work" boosters.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
DoctorScary
Sep 9, 2015 07:53 AM
Sep 8, 2015 11:50 AM
