F150 9" rear
Old Jun 12, 2011 | 01:50 PM
Couper's Avatar
Couper
Default F150 9" rear
Anyone use a 9" rear end from an F 100/150, what'd you do about brakes?
Old Jun 13, 2011 | 05:52 PM
Couper's Avatar
Couper
bumped
Old Jun 13, 2011 | 10:11 PM
andrewmp6's Avatar
andrewmp6
I don't think anyone has used one,But i know the Shelby's that raced used the truck drums in the rear to help brake faster.
Old Jun 13, 2011 | 10:49 PM
jgemperline's Avatar
jgemperline
Do they come with limited slip? What about gear ratio. I assume you need to cut/mod to help wheels fit under the car. Why not use the brakes off a f150? Sorry about the questions but I have never heard this option before. Do you have the rear?
Old Jun 13, 2011 | 11:42 PM
Couper's Avatar
Couper
many came with nice gears, 4:11, trac loc, 31 spline, just not sure about the brake bolt pattern
Old Jun 14, 2011 | 10:27 AM
69mach1377's Avatar
69mach1377
They are wider and the leaf mounts need to be moved, IIRC. With the correct backspacing, wheels may actually fit. I don't recall the pattern diameter.
Old Jun 14, 2011 | 11:33 AM
Couper's Avatar
Couper
Pro Street narrowed with coil overs, I'm just concerned about the brakes, bolt pattern whatever, I don't want to be limited to truck selection for wheels.
Old Jun 14, 2011 | 09:38 PM
andrewmp6's Avatar
andrewmp6
You can always change the bolt pattern on it,For brakes wilwood makes a ton for the 9 inch so that's not a problem either.
Old Jun 15, 2011 | 08:06 AM
frdnut's Avatar
frdnut
Some of the F100s have the 4 1/2 bolt pattern the same as a car..Lots of modifications required to fit one in a mustang though.
Old Jun 15, 2011 | 01:35 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
FoMoCo sells rear disc setups from Rangers that bolt onto the earlier 9" axles. Cheap, cheap, cheap. Last time I checked they were somewhere around the 300.00 setup. All Ford parts.
