Headlights randomly dim.
Old Jun 12, 2011 | 04:46 PM
dano670's Avatar
dano670
Default Headlights randomly dim.
My 65 with an alternator randomly headlights randomly dim completely. I have replaced the headlight switch but that didn't solve the problem. I also finally replaced my battery (which lasted 6 years). Whenever it feels like it, the headlights will cut off and even though the instrument gauges still work well. I am looking for a ground wire problem as right now, shutting the doors firmly seems to restore things for a while. I have heard that Haologens overtask the breaker in the switch, the cars acts the same no matter what head light switch I have in the car.
Any suggestions?
Old Jun 12, 2011 | 05:04 PM
MustangFTW
Guest
Posts: n/a
sounds like a ground issue, also make sure you light bulb are properly inserted and are not moving around.
Old Jun 12, 2011 | 05:23 PM
2+2GT's Avatar
2+2GT
Classic symptom of overloaded headlight circuit breaker. As they age, they can't take as much power draw. I have halogens, and they are OK. You could try a 69 switch, that was for 4 light system.
Old Jun 12, 2011 | 08:09 PM
JMD's Avatar
JMD
Relays are wonderful solution to high draw/inadequate circuit situations...
Old Jun 12, 2011 | 09:21 PM
2+2GT's Avatar
2+2GT
There is actually a plug-in relay harness setup for high-power headlights in older Mustangs.
Old Jun 12, 2011 | 09:36 PM
MustangBradley's Avatar
MustangBradley
I set up my headlight switch to control a relay that switches the headlights. Ended my headlight problems.
Old Jun 12, 2011 | 10:54 PM
tx65coupe's Avatar
tx65coupe
I also think that running relays is a great idea with Halogens. It can also make the lights brighter since more voltage reaches the lights.
I am using this relay setup. I am very happy with it.
http://rjminjectiontech.com/products/headlight-harness
Old Jun 13, 2011 | 05:49 AM
kalli's Avatar
kalli
Originally Posted by tx65coupe
I also think that running relays is a great idea with Halogens. It can also make the lights brighter since more votage reaches the lights.
yep. that's the one. on my to do list as well
Old Jun 15, 2011 | 07:54 PM
dano670's Avatar
dano670
So loosed and re-tightened the headlight grounds and redrilled the cylinder head to firewall ground. Problem occurred around the same places on my commute. I never thought of this before, but I forgot to check the the floor mounted high/low beam switch.
Old Jun 17, 2011 | 12:01 PM
MustangBradley
That switch, like all others, can corrode with age and increase the resistance in the circuit. The wires leading up to the switch can also corrode, so check those too.
