"Floating Front End" @ 65 mph
Worn parts, soft suspension, bad alignment, crappy tires.
Suspension is actually a big factor, soft suspension will allow the front of the car to more around more.
I've had mine up to 140mph and it's completely stable, but that's with the 1" a-arm drop, 620 springs, KYB Gas-A-Just shocks, 1.125" sway bar and all poly bushings, with good tires.
Lighter springs and easy to extend shocks will allow the nose of the car to come up at speed which lets more air under the car and can add to instability. You want some movement but lower is often better as long as you still have travel.
Yeah, when I was running bias ply tires, my car wondered at every little change in the road surface. That is because the tire is much more flexible than the new radials.
Definitely check out the bushings and tie rods. That is just a safety thing.
I'm having the same issue with my 2011 Premium Convertible (6 cyl). I switched out the tires to BFG T/A's and have a much smoother ride, but still front end lift at 80 mph without fail on any freeway driving surface. It reminds me of the drift I had on an '87 Z28. I haven't owned an American care since then. It seems like it must be a weight and suspension issue unique to these light American pony cars.
Guest
Posts: n/a
breaking
Oct 2, 2015 01:27 PM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
