First engine build 65 fastback
Old Jul 7, 2011 | 04:21 PM
baypark's Avatar
baypark
Default First engine build 65 fastback
I'm doing my first engine build and thinking about swapping for a 302. Any advice for whether I should go with an older 302 or get the roller motor. How difficult is it to have the roller motor with a carburetor instead of EFI? How difficult is it to find other parts between the two motors?
Old Jul 7, 2011 | 04:26 PM
MustangBradley's Avatar
MustangBradley
Rollers have less things to worry about. Cam break-in is not as critical as a solid cam setup. Are you looking at buying a short block/long block or buying parts and doing it yourself?
Having a roller setup does not impact your induction choice. Parts are plentiful for both.
BTW, welcome to the Forum. Glad you are here.
Old Jul 7, 2011 | 04:30 PM
baypark's Avatar
baypark
Thanks. I'm looking at the short blocks and I'm going to try buy parts and do it myself.
Old Jul 7, 2011 | 06:49 PM
67t5ponycoupe's Avatar
67t5ponycoupe
I like to leave the engine building for experts. You might consider a crate motor. They are warranteed and a lot less hassle.
Old Jul 8, 2011 | 10:25 AM
OCHOHILL's Avatar
OCHOHILL
search function.
Old Jul 9, 2011 | 12:11 PM
rusty65's Avatar
rusty65
Well, what do you want to do with the engine once its in your car? Do you want a bad *** gas guzzling strip motor or is it going to be a daily driver on city streets? Im assuming even if it is a daily driver youre going to want to go above and beyond necessity (just like i did) and give it some umph as well. However, either way you go Ocho is right. In fact, he said the same thing to me when i was asking questions about my 302 motor build
Im also assuming that this is your first engine build as well. If it is, i would suggest going with a tried and true set up, such as a fox body 302 approach (for which aftermarket parts are beyond plentiful, and cheap~ish!), because youll be able to find out everything you ever wanted to know, and some stuff you didnt, just by punching it into google. On top of readily available parts and a wealth of knowledge, since they are so popular many auto shops near you will be able to easily assist you if you decide to build it yourself and run into any problems.
My motor build has gone very well so far. I picked up a 1989 HO 302 from a fox body just by chance and found out all the advantages as i went. Man did i get lucky...
Anyway, if youre looking to just get some above stock horsepower and learn how to build motors in the future so that you could potentially upgrade id go with a cookie cutter approach the first time around. For instance, a very popular set up is to take apart the motor, get the crank polished (and ground down 1 undersize if absolutely necessary), put in all new bearings, rods, bolts, buy a ford racing b303 or e303 cam (everyone has their own opinion on these cams, but theyve been used in many many mustang builds across the country), pistons if you need em, piston rings, a set of ported gt40/gt40p heads, lifters for the cam, harmonic balancer, an intake manifold, and a carb. There are of course things i neglected to list, but the main changes are there so you get the idea.
All in all, a 302 from a fox body is a good choice, its very simple to run it with a carb, and parts are everywhere. Plus, it should bolt right into your classic mustang.
Old Jul 10, 2011 | 06:35 AM
MustangBradley
Originally Posted by rusty65
.......buy a ford racing b303 or e303 cam (everyone has their own opinion on these cams, but theyve been used in many many mustang builds across the country), .......
I believe these cams have gotten a bad rap because they are not the max performance you can get. Ford spec'd the profiles to be an all around performance profile. Often I'll read a post that states in all capitals that those "Letter" cams suck, then suggest getting a custom cam but without any profile figures. It has gotten to the point where everyone has been TOLD they are bad cams so they must be. Can you get "better" performing cams? Absolutely. Do the "Letter" cams suck? No, they are just one of 31 flavors at Baskin Robbins.
Old Jul 10, 2011 | 08:15 AM
Coupe's Avatar
Coupe
Also, be aware that the P heads may not like your choice in headers.
Old Jul 10, 2011 | 02:50 PM
Jonk67's Avatar
Jonk67
I kept my stock 289 and put new parts in it, decided to stroke it to 333ci while I was at it. I looked at the roller option but for the cost of the roller parts it wasn't worth the ~15hp differernce to me as I wanted all new parts. The roller cams, lifters, etc. are 2X $ of hydraulic.
Either way you go be sure to keep all your original accessories as the timing covers may be different, fuel pump eccentric, cam gear ht. all varies with motor year.
Jon
Old Jul 10, 2011 | 03:40 PM
Xring01's Avatar
Xring01
I just made went thru this exact dilema. I went with the Roller Cam... Any find my thread...
65 Conv Build... I have all the photos listed there...
About to update it again..
Nick Oliver
Oct 17, 2018 04:22 AM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
