no brake tail or dash lights
Old Jul 19, 2011 | 01:34 AM
66-pony's Avatar
66-pony
Scottybaccus thank u u are a god send it was the flashers thank u so much after a three day headache thank u for all ur help
Old Jul 20, 2011 | 08:33 AM
MustangBradley's Avatar
MustangBradley
Note to new member 66-pony. We love helping our fellow Mustang owners, but three threads are two too many for one problem. I replied to the other two, thinking you had received no help, then I find this one where the bulk of the responses have been posted.
I am happy you got your answers though.
Old Jul 20, 2011 | 10:10 AM
66-pony's Avatar
66-pony
sorry for the multiple threads still getting use to the way the website works. I still dont have it fixed. but have narrowed it to turn singal switch
Old Jul 20, 2011 | 04:48 PM
MustangBradley
Do you have the wiring diagram? More importantly, do you know how to trace circuits based on the wiring diagram?
Old Jul 20, 2011 | 04:54 PM
66-pony's Avatar
66-pony
Yes I do but it has to b constant hot becauseit continues with all fuses pulled
Old Jul 21, 2011 | 08:12 AM
MustangBradley
That is curious. This is a subject I have meant to investigate, but have not as of yet. On the original diagram (I posted the link below) you'll notice wire 25 feeds the headlight switch with power from a splice with wire 37. Notice 37 goes to the starter solenoid. The way I am reading this is that by consequence, wire 25 is unfused between the power source and the switch itself. This would explain why you are still getting power even with all of the fuses pulled. Some members have mentioned a fuse that is part of the headlight switch, but I have never seen one. All of the switches I have pulled from my 65 have not had a fuse. That may have changed with the 66, or my switches have been the wrong one.
http://hammar.dyndns.org/~djhamma/wi...6/66exter1.jpg
Old Jul 21, 2011 | 12:03 PM
TexasAxMan's Avatar
TexasAxMan
The headlight switch receives unfused power. It has an internal circuit breaker.
Old Jul 21, 2011 | 03:56 PM
MustangBradley
I knew about the circuit breaker, but did not consider that it would be used in place of a fuse. Thanks for solving the mystery.
Old Jul 21, 2011 | 06:28 PM
66-pony's Avatar
66-pony
i replaced the steering wheel hub and that did not correct the issue
Old Jul 22, 2011 | 03:52 PM
MustangBradley
Could you describe the current problems? Since you replaced parts, and have had a few threads, why don't we do a reset and start again. Give a rundown of all you've done to try to fix it as well.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
mungodrums
Oct 7, 2015 04:01 AM
tmdm
Sep 4, 2015 06:45 PM
amandahchase
Sep 3, 2015 10:09 AM
