Power Steering Fluid?
Old Jul 22, 2011 | 04:27 PM
Fordication's Avatar
Fordication
Default Power Steering Fluid?
Hey guys. I have to replace my power steering hoses. One blew about a week ago and dumped the contents on the garage floor. What should I use to refill the reservoir? ATF mercron or power steering fluid. 72 mustang with a 351C if you want to know. Thanks
Old Jul 22, 2011 | 05:15 PM
JMD's Avatar
JMD
IDK, I use ATF all the time, seems like that is what I usually have on hand.
IMO, Type F Dextron, Mercon, etc, I don't think it makes a damn bit of difference...
Old Jul 22, 2011 | 05:52 PM
2+2GT's Avatar
2+2GT
The book calls for Type F.
Old Jul 22, 2011 | 06:17 PM
chockostang's Avatar
chockostang
Yes use Dexron, Off the self ATF, Bargain brand Imported SPECIAL Design Power Steering Fluid, see what happens.
You might get by with the lower Viscosity at the higher temps, then again you may not???
Dan @ Chockostang
Old Jul 22, 2011 | 06:37 PM
JMD's Avatar
JMD
Dan @ Chockostang
uh,,, yea....
And make sure to flush the antifreeze out of your car every spring and replace it with coolant for the summer, in the fall make sure to reverse the process....
ATF is hydraulic fluid with different friction modifiers added in, which power steering could care less about. Any ATF made for domestic vehicles is good enough for power steering for any domestic vehicle. Probably good enough for foreign makes as well, but I understand this may not be true with Hondas.
I guess type F is the right one, if someone is going to worry about it go with type F..... But I don't worry about it....
Old Jul 22, 2011 | 07:36 PM
Fordication
Well it blew the hose for no reason and its has been whining a bit lately. I used power steering fluid on the last top off. Thats why I am asking.
Old Jul 22, 2011 | 08:41 PM
JMD's Avatar
JMD
Power steering fluid is fine. A whine usually is indicative of tiny air bubbles being trapped in the fluid, or of course low fluid level.
If the fluid is up, the whine should go away in a little time.
Old Jul 22, 2011 | 09:46 PM
Fordication
Sorrry too late. I got the type f atf flud and my new hoses. Thanks anyways. Its why I like this forum. Get quick answers when you need em.
Old Jul 23, 2011 | 09:38 AM
Starfury's Avatar
Starfury
Easier to pick up a bunch of Type F and save the extra. That way you're covered on p/s and tranny fluid
Old Jul 24, 2011 | 03:00 AM
Fordication
Well I got the hose yesterday and tried to install it. Freaking Advance Autos hose does not fit. It does not have the flare fitting on the PS pump either. You would think that would be an easy purchase but no. Now I have to wait another week to get one from a mustang store.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
stark777
Sep 21, 2015 12:46 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
IronRaptor
Sep 9, 2015 08:10 AM
