Engine vacuum question
Old Aug 10, 2011 | 08:45 PM
ChesterKaup's Avatar
ChesterKaup
Default Engine vacuum question
The car is a 1966 mustang with a 289 4 bbl engine and C4 automatic. Engine was recently rebuilt. It has a slightly larger cam measuring duration @ .050 at 204 intake and 214 exhaust. Rest of rebuild is pure stock. I have the timing set at about 12 degres BTDC. I can get 18-19 inches of vacuum in Park at an idle speed of 800-900 RPM. When I put it in drive vacuum drops to 13 inches and RPM to 600, I tried cranking up the RPM with it in drive but no increase in vacuum. I tried disconnecting and plugging the trans modulator hose but that did nothing. Is this normal?
Old Aug 10, 2011 | 09:17 PM
67mustang302's Avatar
67mustang302
What stall converter? And 18-19 idle is pretty tame.
Regardless, does it idle well in gear and run right? If yes, then don't worry.
Old Aug 10, 2011 | 09:59 PM
ChesterKaup
The transmission was rebuilt with a stock converter.
Old Aug 11, 2011 | 12:14 AM
Gun Jam's Avatar
Gun Jam
Im gonna guess its normal...Engine rpm drops due to load when in D adding load always drops vac. I get 13-14 at idle 0 at WOT and 25" coasting at high rpm.
Again if it runs fine dont worry.
-Gun
Old Aug 11, 2011 | 06:06 AM
kalli's Avatar
kalli
don't forget that when you drop it into drive you probably stand on your brakes, when you have a servo this can change the vacuum reading as well.
like 67m302 said 18-19 is very good vacuum reading. and I think 12-13 in drive at 600rpm is a good signal.
there's probably no need for worry
Old Aug 11, 2011 | 09:02 PM
67mustang302
If I had 18" vacuum at idle, I'd suspect that my timing chain jumped teeth and advanced the crap out of my cam.
ShaneB26154
35
Mar 4, 2021 04:05 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
classic69FB
Aug 12, 2015 11:58 PM
HIS S-197
Aug 10, 2015 05:47 PM
