wrapping headers
Old Aug 15, 2011 | 12:04 AM
66-pony's Avatar
66-pony
Default wrapping headers
i have a66 mustang with a 86 5.0 motor i am thinking of wrapping the headers is this a good idea and if i wrap the headers do i need to wrap whole system. with such a small engine bay it is getting pretty warm under the hood and am looking for ways to decrease heat thank you in advance for your help
Old Aug 15, 2011 | 02:02 AM
1ofakind's Avatar
1ofakind
ive heard that the wraps keep in moisture, later causing it to rust premature
Old Aug 15, 2011 | 04:37 AM
kalli's Avatar
kalli
two-sided sword, as 1ofakind says can cause other problems. In many cases the headers crack, since they can't get rid of the heat. If you buty the headers there's usually a note with it that warranty is void when you wrap them
Old Aug 15, 2011 | 06:41 AM
andrewmp6's Avatar
andrewmp6
Just get the headers coated locally is the best option.
Old Aug 15, 2011 | 11:28 AM
frdnut's Avatar
frdnut
I agree..Make sure the headers fit and do any dimpling of the tubes if necessary for clearance first..Then send them out for ceramic coating..
Old Aug 15, 2011 | 07:22 PM
racer_dave's Avatar
racer_dave
Get them coated, wrapping is a pain in the a... and it will start to come loose, holds moisture... and the coating looks better too.
Old Aug 16, 2011 | 11:31 AM
66-pony's Avatar
66-pony
the motor is already in the car but the car is vapor locking last week it was in a parade and vapor locked twice. looking for a way to cool under the hood. what kinda coating would you suggest
Old Aug 16, 2011 | 09:29 PM
racer_dave's Avatar
racer_dave
I'd start with tracing the gas line and move it to get it further from the heat, or get some of the fiberglass heat shield and insulate the gas line.
Make sure the float level in the carb is set high enough. If its too low and you have higher carb temps it might be affecting it.
Change to a thicker carb gasket or get a phenolic/resin spacer. This will keep heat out of the carb that may be getting transmitted to the carb from the intake manifold.
Another trick is to run a bit larger gas line which sould be able to dissapate(sp?) heat better.
Old Aug 17, 2011 | 12:50 AM
andrewmp6's Avatar
andrewmp6
Most of the time vapor lock is not having a carb spacer or the fuel line to the carb too close to the engine.As far as coasting look in your phone book for a ceramic coating company every big city has a few so price shop around.Price can be 150 bucks to 300 depends that temp the coating is rated to and the color they can do it chrome looking or colors like powder coating.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Roxon68
Mar 17, 2016 08:13 PM
junior04
Sep 28, 2015 10:53 AM
Sep 18, 2015 06:49 PM
BrantleyS550
Sep 14, 2015 04:18 PM
