transmission removal
Old Aug 15, 2011 | 07:06 AM
gooser's Avatar
gooser
Default transmission removal
66 coupe, 289 engine and c-4 transmission. i need to remove the engine and transmission later this week and i would like to remove them both as a unit. what all do i need to disconnect at the transmission end so that it'll slide on out? obviously i know i need to disconnect the driveshaft, transmission mounts, shifter and any wiring i see around. anything else? thanks.
Old Aug 15, 2011 | 08:05 AM
Coupe's Avatar
Coupe
Unhook the lines at the trans end, pull the radiator to prevent damage and dont forget to use an output shaft plug to keep the tranny fluid from coating your work area.
Old Aug 15, 2011 | 08:47 AM
gooser's Avatar
gooser
thanks coupe. i forgot about the fluid. guess i'll drain it first.
Old Aug 15, 2011 | 10:52 AM
Coupe's Avatar
Coupe
You may want to still get a plug, that tq converter holds about 60 gallons.
Old Aug 15, 2011 | 12:56 PM
MustangFTW
Guest
Posts: n/a
highly doubt 60 gallons lol, i used an ice cream bucket (preferably empty)
and a 5 gallon bucket 1/2 full.
also you might need to remove starter.
Old Aug 15, 2011 | 04:19 PM
Coupe's Avatar
Coupe
When it spills all over the floor it "looks" like 60 gallons. :-)
Old Aug 15, 2011 | 04:51 PM
MustangFTW
Guest
Posts: n/a
sure does lol.
Old Jul 3, 2012 | 09:03 PM
Falcopilot's Avatar
Falcopilot
Is an output shaft plug something I can purchase? Or what do you use?
Old Jul 3, 2012 | 09:51 PM
MonsterBilly's Avatar
MonsterBilly
Default pvc
Im pretty sure a 1" of 1-1/4" pvc cap works. you can get them both at home depot for about $1 each.
Old Jul 3, 2012 | 10:09 PM
Falcopilot's Avatar
Falcopilot
Sounds good to me!! Thanks!
