just installed engine, quick questions.
Old Aug 26, 2011 | 11:53 AM
MustangFTW
Guest
Posts: n/a
Default just installed engine, quick questions.
so i finally got my engine transmission back in yesterday, took a while to get the transmission connected to the driveshaft since we had on the chains a bit skewed :P, now i need to connect tubes/accessories and add fluid and try it out!
so i have a couple questions
    Old Aug 26, 2011 | 11:59 AM
    TexasAxMan's Avatar
    TexasAxMan
    That thick wire is your main ground. It must be replaced or you'll have all kinds of problems. Get a decent ground strap (available at all auto parts stores) and make sure the connections are clean and tight.
    Old Aug 26, 2011 | 05:45 PM
    Stepman's Avatar
    Stepman
    To fill the trans, I'd pour in 4 quarts, then start it up. Run it thru the gears and you'll notice that there are none. Add fluid slowly, a quart at a time, going thru the gears once in between. You'll notice that suddenly, it seems to have gears. That's when you're getting close. Now you can continue adding as you check the stick. Let it settle for a few seconds (after adding) before you check it. Look at both sides of the stick and one side will be "lower". that is the correct one.
    Should take 10 or 12 quarts?
    When connecting the linkage, I put it in the "neutral gate". If you move the shifter all the way one direction, grab the drive shaft and see if it locks. You need the rear wheels off the ground for that. You'll also notice that if it is in park, there is a bigger distance to rev...or the first detent than there is if you're on the other end.
    For the ground cable, go to the store and look at the battery cables. You can find them with eyelets instead of cable clamps on both ends.
    Old Aug 26, 2011 | 10:52 PM
    MustangFTW
    Guest
    Posts: n/a
    so if its in neutral the DS should turn by hand, is this done before filling, during filling..?
    Old Aug 27, 2011 | 08:00 AM
    Stepman's Avatar
    Stepman
    I would hook everything up before I filled it. Yes, the driveshaft will turn in every gear...except park.
    Old Aug 27, 2011 | 08:35 PM
    MustangFTW
    Guest
    Posts: n/a
    so i forgot to set the engine to TDC before putting it in, how would i turn the engine to TDC with it in the car? do i put it in drive and push it...??
    Old Aug 27, 2011 | 08:59 PM
    1slow67's Avatar
    1slow67
    ROTM Moderator
    I either use a breaker bar and manually turn the crank pulley or use the starter.
    Old Aug 27, 2011 | 10:09 PM
    MustangFTW
    Guest
    Posts: n/a
    so i should be able to keep it in park and use brute force to turn it? just didnt want to break anything
    how would i use the starter?
    Old Aug 27, 2011 | 10:40 PM
    1slow67's Avatar
    1slow67
    ROTM Moderator
    I would put it in neutral and yeah it actually isn't that hard. As for the starter you just use short bursts with it. I prefer using the breaker bar method.
    Old Aug 27, 2011 | 11:25 PM
    boogerschnot's Avatar
    boogerschnot
    Must folks reccomend you filling the torque converter before installing it to help prime the pump. Hopefully you dont have any troubles wwith that.
