what carb
Old Sep 6, 2005 | 04:39 PM
mlitz's Avatar
mlitz
Default what carb
ok i need to find out what my carb is so i can re build it, its a 4bbl holly. were should i look? or who should i ask? i need to find out.
Old Sep 6, 2005 | 04:52 PM
harald's Avatar
harald
Default RE: what carb
normally on holleys the list number is stamped on the air horn, wich is the round thing on the top that you fit your air cleaner over (if you look at it from above its the circle with the four holes in. for example 1850-4 something something.
write down this number and go to the holley site and search for that number.
you will get a listing of all numbers they have and on that list it gives you the carb specifics...
hope that helped.
Old Sep 6, 2005 | 06:44 PM
mlitz's Avatar
mlitz
well i forund the # its 1850-4 then below the # is 1117 i looked on the holley web site and could not find it
Old Sep 6, 2005 | 07:34 PM
nualln's Avatar
nualln
The 1850-4 is a 600cfm holley 4160.
Here is the rebuild kit:
http://store.summitracing.com/defaul...=KeywordSearch
but you could probably get it from autozone or pepboys/napa.
Old Sep 6, 2005 | 08:04 PM
mlitz's Avatar
mlitz
what is the differance between the 3 kits.....Trick, Fast, Renew
Old Sep 7, 2005 | 01:10 AM
nualln's Avatar
nualln
Im not sure, just get the renew kit.
Old Sep 7, 2005 | 05:36 AM
65_2plus2's Avatar
65_2plus2
Holley's Fast Kits include the most commonly replaced parts you'll need to bring your Holley carb back to its original condition. (Economical cost)
Holley Renew kit brings your carb back to original specs and like-new condition! (Mid-range cost)
Holley Trick Kits are the inexpensive solution to fuel slosh in your carburetor. The kits contain all of the parts you need to perform a complete rebuild on your Holley carb for, including part to performance tune such as accelerator pump discharge nozzles and extra gaskets, a vent baffle, high-flow needle and seat assemblies, high-capacity power valves, pump cam and secondary opening spring assortments, gaskets, and O-rings. (most expensive)
Cheers.......[sm=icon_cheers.gif]
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
