power steering pump adjustment
Old Sep 12, 2011 | 08:03 PM
hotrod351's Avatar
hotrod351
Default power steering pump adjustment
well im replacing my power steering pump for the second time in 4 years, lifetime warranty from checker. problem is leaking from the reservoir front oring. im thinking it might be from the way i tension it. the pump bracket i have is the old style that you have to pry on to adjust it. it would of been nice to have one of the later style with the adjusting bolt but not. anyway im now trying to find out the best way to pry on it without doing any damage to the reservoir. even with a lifetime warranty i dont really want to be replacing the pump every two years. 1970 mustang coupe. 302 engine. factory AC.
Old Sep 18, 2011 | 08:43 AM
hotrod351's Avatar
hotrod351
bumpty bump
Old Sep 18, 2011 | 12:34 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
i deleted my PS...i hate it in any vehicle i own...post a a picture of your setup
Old Sep 18, 2011 | 01:46 PM
hotrod351's Avatar
hotrod351
already done. i found if i put a small hyd. jack on the front cross brace i can put enough pressure upwards against the front of the pulley to get it tight.
Old Sep 18, 2011 | 06:12 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
i think youre over tightening your belts on the pumps leading them to failure...
Old Sep 18, 2011 | 06:21 PM
2+2GT's Avatar
2+2GT
I usually put a large screwdriver between a couple of the mounting bolts, then tighten the adjusting bolt. You should never never never never pry on the reservoir tank.
Old Sep 18, 2011 | 07:04 PM
hotrod351's Avatar
hotrod351
well good thing its done. didnt pry on the res. anyway maybe ill get another two years out of this one. good thing they come with a lifetime warranty.
Old Sep 18, 2011 | 08:12 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
if youre tightening them enough to cause failure in the then youre causing damage to your main bearings in the engine, bearing in the waterpump etc whats ever is on that same belt....
i assume youre over tightening them to eliminate belt squeal?
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
9550
Oct 26, 2015 05:01 PM
uberstang1
Sep 20, 2015 06:42 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
