Heater Blower Output
Old Sep 21, 2011 | 11:25 AM
unit91's Avatar
unit91
Question Heater Blower Output
Replaced blower motor and refurbished the heater box. All vent and defroster controls work fine but even on high the amout of air doesn't match a new car. Is that customary with these older cars?
Old Sep 21, 2011 | 03:55 PM
2+2GT's Avatar
2+2GT
No. A properly operating Mustang heater on full blast should have your passengers begging for mercy.
Old Sep 21, 2011 | 09:37 PM
1965fastback's Avatar
1965fastback
Are you getting the proper amount of voltage to the blower motor?
Old Sep 22, 2011 | 08:23 AM
unit91's Avatar
unit91
What's the test for that?
Old Sep 22, 2011 | 10:04 AM
unit91's Avatar
unit91
Does the instrument cluster voltage regulator have anything to do with that?
Old Sep 22, 2011 | 12:26 PM
2+2GT's Avatar
2+2GT
No. The 3-speed heater blower gets a full 12V to the motor at all times. When the switch activates, it grounds the motor either directly to ground (high) or to two resistors mounted on the heater box, providing medium or low speeds.
Old Sep 22, 2011 | 02:33 PM
unit91's Avatar
unit91
Well, I get 3 speeds. I replaced the switch, blower motor, and resistor. Just don't get a lot of air thru the defroster or vents. I cleaned out and refurbished everything. Maybe I'll put the old resistor back in and see if that makes any difference.
Old Sep 22, 2011 | 03:10 PM
2+2GT's Avatar
2+2GT
The resistor is not involved with "high".
Do you have that crappy original cardboard plenum?
Old Sep 22, 2011 | 03:22 PM
unit91's Avatar
unit91
I think the plenum is the black piece that the hoses connect to that go to the defroster? If I'm right it's made of plastic and appears to be fairly new. Still had the price tag on it. If I connect one of the wires coming from the blower in the engine bay to battery (-) and the other wire to battery (+) to see if motor speed is affected, does it matter which wire goes to (+)?
Old Sep 22, 2011 | 04:00 PM
2+2GT's Avatar
2+2GT
Yeah, if you manage to make the blower run backward, it won't work worth a crap. If your new motor is running backward, it would explain a lot.
