Need help decoding axle tag
Old Sep 9, 2005 | 11:29 PM
earlymustang's Avatar
earlymustang
Default Need help decoding axle tag
Trying to identify rear end and gear ratio by the following code taken from the tag attached to the housing.
Thanks for the help!
0 5CE 906
Old Sep 10, 2005 | 12:35 AM
Riven02's Avatar
Riven02
Default RE: Need help decoding axle tag
Well I have a shop manual but it doesnt have that code in here. The codes are all in this format "WCZ-G"
Old Sep 10, 2005 | 12:45 AM
earlymustang
Thanks for looking
Old Sep 10, 2005 | 02:23 AM
68COOP's Avatar
68COOP
This may or may not help, but it should be on the info plate on the drivers door.
Old Sep 10, 2005 | 07:11 AM
Soaring's Avatar
Soaring
I ♥ Acer
Get the number off the data plate on your door, then decifer it here.
http://www.mustangsplus.com/tech/stats/stat04.htm
Old Sep 10, 2005 | 09:33 AM
earlymustang
I understand how to decode it from the door tag. I am trying to verify the rear end matches the door tag or if maybe someone swithed it out (rear end) at some point in it's life.
Old Sep 10, 2005 | 10:55 AM
Soaring's Avatar
Soaring
I ♥ Acer
0- 3.00:1 standard
5- 1965
C - March build date
E- Supposed to be the week it was built- Maybe this is a number like a 3?
906 - Plant code
As you can see, these numbers do not tell you much about the rear end.
Old Sep 10, 2005 | 11:05 AM
1965MustangFastback's Avatar
1965MustangFastback
You need the WC** code off the tag! Then I can tell you what the rear end gears you have.
Old Sep 10, 2005 | 04:25 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 1965MustangFastback
Even with that number, some former owner could have changed the gears. The 65 had no numbers matching parts such as the rear end and the tranny matching, etc. so that will be no help. Take a picture of the pumpkin and post it here so we can tell you what rear end you most likely have, such as an 8" or a 9". As far as the gears though, you won't know that for sure unless you tear into the pumpkin. If you suspicion it is the original rear end, then go by the data plate info. If you have a tach, you will be running at about 2100-2500 RPM at 70 MPH with the 3.00:1 rear. Approaching 3000 RPM would be a 355 or more.
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
Sep 24, 2015 09:18 PM
Sep 10, 2015 08:39 PM
