rear shocks
Old Sep 10, 2005 | 07:53 PM
tylerdru's Avatar
tylerdru
Default rear shocks
do i need a like power wrench to tighten the bolts or just a ratchet. the ratchet doesnt seem to work too good.
Old Sep 10, 2005 | 07:59 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: rear shocks
If you are talking about how to get the nut all the way down, then you need to use a pair of vice grips on the shaft with a rag between the teeth of the vice grips to be able to get the nut tight. Just simple logic.
Old Sep 10, 2005 | 08:16 PM
tylerdru's Avatar
tylerdru
i Have some quick grips?
Old Sep 10, 2005 | 08:23 PM
Soaring's Avatar
Soaring
I ♥ Acer
That will probably work. Just get a tool that will keep the shaft from turning while you are tightening down the shock nuts.
Old Sep 10, 2005 | 09:49 PM
6mustang6's Avatar
6mustang6
I used my mighty all powerful hand to hold my shocks and a rachet to tighten the nut down. Worked like a charm.
Old Sep 11, 2005 | 12:45 AM
dodgestang's Avatar
dodgestang
The almighty hand works ok when you are bolting them into the lower mount....its the upper mount that's tricky when working solo.
Impact socket always works for me
Old Sep 11, 2005 | 11:03 AM
6mustang6's Avatar
6mustang6
Yeah, thats what i used them on, Funny thing though, my shocks didn't move at all when i tightned the top nuts.
Old Sep 11, 2005 | 12:42 PM
tylerdru's Avatar
tylerdru
I want an impact socket. do you guys have the kind that use air or the cheap electric kind. I need to buy a compressor.
Old Sep 11, 2005 | 01:08 PM
6mustang6's Avatar
6mustang6
I have an air impact gun, man those things are nice. I have seen a LArge stand up compressor at lowes for like 400. Thats cheap for a big one, but you can buy a little portable one for cheaper.
Old Sep 11, 2005 | 01:19 PM
tylerdru's Avatar
tylerdru
Yeah all i have is a screwdriver set and two 200 piece ratchets sets. They get most of the jobs done. I dont have any floor jacks or jack stands yet. I will buy those when im finished with the engine work and move onto suspension i need leaf springs!
