c4 auto/ Manual
Old Dec 4, 2011 | 03:11 PM
Dats1NiceMustang's Avatar
Dats1NiceMustang
Default c4 auto/ Manual
Hey guys I got a few questions to ask you...I have recently bought a 65 fastback with an inline 6 and auto...I have purchased a full five lug setup with disc brakes, 8 inch rearend and a 1965 289 hipo 6 bolt...My question is now for the transmission, I'm having a hard time deciding between a t5 or a v8 c4...I really like the t5 when I had my 67 coupe, but I really hate to spend all that extra money just converting mine into a manual...Will the c4 hold up to the 289? I'm having it built almost like the shelby 289 but just with a slightly bigger cam..I grew up always hearing "A mustang is not a mustang without a stick shift", but changing gears does get old...I do a little bit a highway driving with my mustang so that is something else that is scaring me with the c4 and not having but 3 gears...I guess I'm just wanting to know what yall's take on it is?...Any info will be great guys, and is anyone changing their manual over to an automatic, if so I may be interested in buying your pedals and stuff... Sorry for any typo's..posting from a cell phone
Old Dec 4, 2011 | 03:56 PM
MustangFTW
Guest
Posts: n/a
C4 should hold up fine, iirc it holds Till 350, but I could be wrong.
Old Dec 4, 2011 | 05:37 PM
Xring01's Avatar
Xring01
C4 will take up to 350hp no problem....
I just rebuilt my engine and tranny.. I am running a roller cam 302, Holley 600cfm and MSD Ignition... Im guessing I am getting 250hp..., but I am not done tuning it either...
The rebuilt C4 is handling everything that this engine has.
The issue that you might not like is that C4 is only 3 speeds... If you already have a c4 then you are good to go... But if you in the position that you need to buy a tranny, then you might want to look into a Ford AOD. This will give you Overdrive... Knock down the RPM's on the freeway, getting you better gas mileage...
Old Dec 4, 2011 | 07:37 PM
Dats1NiceMustang
Well I was told the AOD doesn't fit the transmission tunnel to well on the 1965...Is this correct
Old Dec 4, 2011 | 08:25 PM
Dats1NiceMustang
Also one more question a friend of mine has a 1973 c4 that has been rebuilt will this 73 fit my 65 289?...
Old Dec 4, 2011 | 08:43 PM
MustangFTW
Guest
Posts: n/a
They have different splines for the input shaft, not sure what this means for your 65. You will need to use the 73 TC because its a 26 spline instead of the 24. . The bell housing pattern should be the same
Old Dec 5, 2011 | 08:20 AM
mr_velocity's Avatar
mr_velocity
I put a 4R70W in my 66, fit no problem.
BeatnikFink
Oct 1, 2015 08:00 PM
guitarman376
Sep 30, 2015 05:54 PM
Mustangmalo
Sep 6, 2015 05:22 PM
