NOT STEALING..BUT....
Old Dec 6, 2011 | 11:00 AM
Coupe's Avatar
Coupe
Did that year even have a gearshift lock the worked from the ignition?
Old Dec 6, 2011 | 11:03 AM
MustangFTW
Guest
Posts: n/a
thats what im thinking, it could be that the shifter is just stuck or rusty, easy to check, just crawl under the car and have a look.
Old Dec 6, 2011 | 12:13 PM
LynnBob Mustang's Avatar
LynnBob Mustang
Originally Posted by JMD
IMO the locksmith idea is the best, a locksmith should be able to make a key on the spot without a code.
I like the disconnect the tranny post too....
I'll ask and or say it again, how is a lock smith going to do it without having a key pattern to go by? There had to be dozens of keys made.
Lynn
Old Dec 6, 2011 | 12:26 PM
MustangFTW
Guest
Posts: n/a
Lynn
they do it by using the lock cylinder, the place i work at makes you keys for locks if you bring in the lock...
Old Dec 6, 2011 | 01:40 PM
Dats1NiceMustang's Avatar
Dats1NiceMustang
Got it figured out guys thanks
Old Dec 6, 2011 | 02:12 PM
69mach1377's Avatar
69mach1377
So what worked?
Old Dec 6, 2011 | 02:35 PM
JMD's Avatar
JMD
Lynn
I don't know how the hell they do it but they do. My younger son is in the habit of loosing his keys, he has called locksmiths and had them make keys "on site" more than once..... and more than twice....
Old Dec 6, 2011 | 03:23 PM
TexasAxMan's Avatar
TexasAxMan
I had a locksmith make a key for my old Bronco, he just put the key blank in, using pliers turned side to side. He was turning pretty hard, I thought he might break it, but he didn't. He took some files to it and tried again until he got it to work. Took him about 4-5 tries!
Old Dec 6, 2011 | 03:50 PM
johngt10's Avatar
johngt10
Originally Posted by MustangFTW
get under the car and disconnect the transmission lever from the transmission, click the part it was attached to back 2 clicks, the car should now be in Neutral, each click corresponds to a different gear, eg, one click is reverse, 2 is N, 3 is D etc.
^This, cheaper and faster
Old Dec 7, 2011 | 12:05 AM
andrewmp6's Avatar
andrewmp6
Yeah breaking things just cost more to replace it and being a 71 none of the steering column is remade.A locksmith is the only option to do it to me.
