T-5 Rebuild
Old Dec 6, 2011 | 04:15 PM
Stangman70's Avatar
Stangman70
Default T-5 Rebuild
Hey guys anyone have a good resource material for doing this project. Just bought a used t5 at a goof price but it has 90k on it so I wanted to be safe and rebuild it myself. I have a good selection of tools but not much experience but don't want to pay a shop to do it. Any books, guides, or rebuild kits that you could recommend?
Old Dec 6, 2011 | 05:04 PM
Gun Jam's Avatar
Gun Jam
The only special tool you need is a press and a bearing splitter.
I rebuilt my t5 using this manual, the master rebuild kit from Modern drive line AND a new 1st gear, 2nd gear, and 1&2 slider/reverse. I have the cobra spec t5 so it was worth it.
Spend a day or 2 reading the manual then have a go at it..post photos if you have questions.
http://www.ttcautomotive.com/English...ice_Manual.pdf
Old Dec 7, 2011 | 01:11 AM
Stangman70's Avatar
Stangman70
Another quick question, can I use the late model bellhousing (1990 trans) with my 1970 302 or will have to get an adapter?
Old Dec 7, 2011 | 10:15 PM
TexasAxMan's Avatar
TexasAxMan
You can either use the T-5 bell with a fulcrum spacer and the original z-bar set up, T-5 bell with cable or hydraulic, or use the original bell with a spacer/adapter. You should figure out how you want to actuate the clutch first, then decide which bell to use.
Modern Driveline is the place to go. I found several good how-to's on the net. It's not very hard and with only 90K on it, I bet your bearings are good to go.
It was one of the most rewarding projects I've done yet. Give it a try.
Old Dec 8, 2011 | 11:25 AM
Stangman70's Avatar
Stangman70
Thanks Tex. I am planning on going with the hydraulic setup bur I am not sure about the external or internal slave system.
Old Dec 8, 2011 | 11:17 PM
MonsterBilly's Avatar
MonsterBilly
I went with a external slave and it was reasonably priced. I bought most of the stuff from an offroad shop here. if i remember correctly i purchased a 7/8" master, a slave, a ss line,from them and a resevour from a harley shop. I think it was about $225 total. I also bought a 1.5' exhaust flange that worked perfect as a backing plate for the master cylinder. I made the offset linkage from the pedal to the master myself with a couple bolts and a welder.
Totally worth it.
However, i did buy the bracket for the slave from one of the venors on the site here. I had made one but did not trust the durability.
Old Dec 9, 2011 | 12:44 PM
Stangman70's Avatar
Stangman70
Monster, do you have any pics of you what you did? Also, was your exhaust flange really one and a half feet or is this a typo? how long was your ss line? and how large was your reservoir? Where did you mount the bracket for the slave?
Old Dec 9, 2011 | 08:02 PM
chris66dad's Avatar
chris66dad
Here are pics/parts/vendors I used for my hydraulic clutch. I spent about $220.
http://chris66dad.tripod.com/id32.html
Old Dec 9, 2011 | 08:21 PM
Stangman70's Avatar
Stangman70
Thanks for the awesome post! This was exactly what I was looking for!
Old Dec 9, 2011 | 10:31 PM
chris66dad's Avatar
chris66dad
I also have info from my T5 swap on my website:
http://chris66dad.tripod.com/id38.html
http://chris66dad.tripod.com/id33.html
http://chris66dad.tripod.com/id34.html
http://chris66dad.tripod.com/id44.html
I was fortunate to find an 89 T5 that was in good condition for $350. If I need to rebuild it, I will add parts to make it a T5z.
It requires a lot of attention to detail. I know a few people who have done a rebuild
