traction master install Q
Old Dec 15, 2011 | 11:49 PM
MonsterBilly's Avatar
MonsterBilly
Default traction master install Q
So i have a 8.8 from an explorer. It has 3.125 axle tubes which create a small issue with mounting the traction master traction bars. The bolt pattern is off on the mounting brackets.
So i grabbed a bur bit and egged out the holes and cut the tabs off and rotated them 90*. now they fit the bolt pattern.
So, should i remove the nuts on the u bolts so the mount sits flat on the bottom shock mount plate, or can i slide them on without taking the nuts off the u bolts and add a second set of nuts. this way the traction master bars would be 1/2" or so off of the shock plate with the nuts spacing them apart. i am afraid that the mounting plate may bend after too many romps. I dont know how mush force the traction bars see.
I can take the nuts off but i was just wondering if they need to come off.
Old Dec 16, 2011 | 05:14 PM
67 evil eleanor's Avatar
67 evil eleanor
Leaving the nuts on will allow more stability but may be out of the range the engineers designed them for. It it was me, I would mount them just like the instructions say. If the old mounting plates are bent, then a few good wacks with a 5 lb hammer will do wonders.
Old Dec 16, 2011 | 09:40 PM
MonsterBilly
there were no instructions
mtgldr
Feb 3, 2024 09:00 PM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Luke9222
Oct 22, 2015 11:55 PM
Sep 8, 2015 11:50 AM
iculookin
Sep 2, 2015 12:34 PM
