Rocker molding delete?
Old Jan 4, 2012 | 05:12 PM
oxfordbp's Avatar
oxfordbp
Default Rocker molding delete?
I to get rid of the rocker moldings. Can I just drill out the rivets on the clips and weld up the holes or fill them with filler?
Thanks
Old Jan 4, 2012 | 06:05 PM
2+2GT's Avatar
2+2GT
Sure- It's been done both ways many times.
Old Jan 4, 2012 | 06:32 PM
1slow67's Avatar
1slow67
ROTM Moderator
That is what I did
Old Jan 4, 2012 | 06:39 PM
oxfordbp's Avatar
oxfordbp
Sweet. Just making sure!
Old Jan 6, 2012 | 01:56 PM
ezstang's Avatar
ezstang
Yes I did the same thing. Eliminate another place for rust to occur
Old Jan 6, 2012 | 03:21 PM
oxfordbp's Avatar
oxfordbp
Yup my thoughts exactly!
Old Jan 6, 2012 | 04:14 PM
groho's Avatar
groho
just be careful on the welding, the inside of the rocker is galvanized, and it results in some nasty welds if you penetrate too deep.
Old Jan 6, 2012 | 04:33 PM
oxfordbp's Avatar
oxfordbp
Would a good filler be ok?
Old Jan 7, 2012 | 06:10 AM
2+2GT's Avatar
2+2GT
Hmmm… I filled the rivet holes in my 66 in 1975, then put 300,000 miles on it. No rust at the holes yet.
Old Jan 7, 2012 | 09:17 AM
Coupe's Avatar
Coupe
I just welded mine, it was a fairly simple ordeal. I did not like the idea of spending money for paint materials and then taking a chance on a bubble forming on a covered hole. It would probably be fine to fill it, just brush some epoxy on the edges of the hole first since drilling the rivits could have removed or scratched the galvanize coating, you don't want any rust starting under the paint.
