Constant power steering pump failer
Old Jan 4, 2012 | 05:45 PM
hotrod351's Avatar
hotrod351
Default Constant power steering pump failer
well looks like im putting on my 5th power steering pump, thats right 5th. i keep getting a leak on the housings. this one lasted a couple months. wife said it made noise shortly after i installed it. is there something im missing. every thing was replaced years ago, hoses and ram, control valve. worked fine for years, then got a leak. replaced it but the one i put on leaked right off the bat, replaced it and it worked for couple months. and no im not prying on the housing to tighten it. i cant figure why so many would do this, lousy rebuilds ? next one im getting from autozone, last 5 came from checker.
Old Jan 4, 2012 | 06:07 PM
2+2GT's Avatar
2+2GT
If you ever need another, you need a better source.
Old Jan 4, 2012 | 06:24 PM
hotrod351's Avatar
hotrod351
yeah thats what im thinking. one other thing im going to check is if its foaming, could have a air leak. at least its something to check.
Old Jan 4, 2012 | 09:44 PM
MonsterBilly's Avatar
MonsterBilly
I am on my 3rd in 3 years. Same thing. Housing is leaking. I was thinking next time i get one to run a small weld aroud the housing and the mounting bolt before i install it.
Old Jan 5, 2012 | 07:08 AM
hotrod351's Avatar
hotrod351
well come to find out its one of the little pressure hoses this time. i think ill just have checker get me all the pressure hoses, they are guaranteed for life so mine as well replace them all.
Old Jan 5, 2012 | 09:50 AM
hotrod351's Avatar
hotrod351
well i was wrong there. its the rear high pressure hose. this is the second one to leak at the crimp fitting. i replaced it year ago. still id think id get more than a few years out of one.
Old Jan 10, 2012 | 06:29 PM
hotrod351's Avatar
hotrod351
well replaced the rear section pf high pressure hose and now pump makes noise. ok so i get another, new fluid and bleed. drove it few miles and made sure it was full. the only problem with this pump is at a complete stop, if i turn the wheel right and left i can hear the pump, dont hear it when i drive, but at a full stop. guess ill drive it for a couple hundred miles and see if it gets better. as i remember it didnt make any noise when sitting and turning the wheel. i think if it doesnt clear up ill change to autozone, just hope they dont get theres from the same place as checker.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
9550
Oct 26, 2015 05:01 PM
uberstang1
Sep 20, 2015 06:42 PM
rksnow1
Sep 14, 2015 08:46 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
